Had a learning experience with my welder, just thought I would share, (engine drive)
   / Had a learning experience with my welder, just thought I would share, (engine drive) #21
You fellers are killing me with those stories. I took a peek inside one of those little foil covered books when I was a kid.:shocked: My contribution to this discussion is the day I learned a little bit about high volt power lines and respecting firefighters. A box truck hit a power pole causing lines to fall on the truck. Grass was burning,sparks flying,smoke and just a general fireworks show. The driver was sitting in the cab scared stiff. I about had him convinced that as long as he wasn't touching both truck and ground at same time he wouldn't be hurt. My instructions were to stand on the running board leap through the air to ground. Suddenly there was a voice from behind me that said"do not move one finger until I say so" at the same time a hand on my shoulder pushed me to the ground and same voice said"plant you ***** right here and don't you say another word". After power was cut off,driver safe and order restored,the young firefighter came over,smiled and said get up and come share some water while I talk to you. He explained how a high voltage arc could follow the hapless driver killing him mid-air. BTW,I learned something else that day,sometines a liitle knowledge can be more dangerous than no knowledge at all.
I posted a video that was made by a power company on how to exit your vehicle when the threat of fire and explosion outweighed the threat from electrocution.. It amounts to never letting much distance between your feet.
I will see if I can find it again.
1996 Sunflower 1543-38 Folding Disk (A61307)
1996 Sunflower...
FUTURE 60" PALLET FORK (A60432)
FUTURE 60" PALLET...
2021 Kubota SVL75-2 Track Loader (A61306)
2021 Kubota...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2019 CATERPILLAR 304E2 CR EXCAVATOR (A60429)
2019 CATERPILLAR...
2010 Ford Fusion Sedan (A59231)
2010 Ford Fusion...
