Had it actually been broken, it would have been more difficult to fix
   / Had it actually been broken, it would have been more difficult to fix #1
square1
Michigan
Ford 1700 4x4 w/ FEL
So, when I installed the kitchen faucet 3 1/2 years ago, there were no instructions in the box. The diverter valve had two outlet connections with the same size fitting to which each of a flexible hose was to be connected. One was for the sprayer, the other for the spout. Logic dictated the sprayer would hook to the longer tube (as sprayers need occasional replacement and it would be easier to unhook than the short tube) with the smaller diameter (because sprayers require less flow) so I set to work. While lying on my back and standing on my head simultaneously I became disoriented and hooked them up exactly backwards of the carefully thought out logic. Well, the flow at the spout was a little low, but I could take paint off the wall across the room with the sprayer.
Fast-forward 3 1/2 years: The spout flow recently had become painfully low while the sprayer pressure had increased to where it was now possible to remove layers of plaster from the far wall in the next room over. This morning's project was to swap the two hoses and regain use of the kitchen sink! I carefully unhooked and rehooked (exactly as they were before :rolleyes: )the hoses. Turned the water back on and the flow to the sink was even worse, however I could now wash my neighbors windows from my kitchen with the sprayer. Upon closely inspecting my work and noticing the hoses had not been swapped I again disconnected and reconnected the hoses, except this time a picture was taken for reference (I don't remember how I used to keep things straight before having a camera phone). Success! The hoses were indeed swapped! I turned the water back on and the flow at the spout was barely a trickle, but the sprayer now worked without having to even depress the button to turn it on. :confused:
As a last gasp attempt to not buy a new faucet I cleaned the aerator. It's all good now :mad:
   / Had it actually been broken, it would have been more difficult to fix #2
LOL!
Sorry for laughing but you're a great story teller. Good to hear your all fixed up.
   / Had it actually been broken, it would have been more difficult to fix #3
You do have a flair with the story. glad, all all is going well now.!.. Can't wait to hear how the "getting the logs out of the hollow" saga goes.:D
   / Had it actually been broken, it would have been more difficult to fix #4
...the sprayer now worked without having to even depress the button to turn it on.
I always like the rubber band on the sprayer button trick...
Pat's QH and hydraulic top-link.
Pat's QH and...
Preliminary Listing / Full Catalog Coming Soon! (A60462)
Preliminary...
2023 Bobcat T770 (A60462)
2023 Bobcat T770...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2018 Husqvarna 21in. Push Mower (A59231)
2018 Husqvarna...
