Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #3,231
Probably a blasting cabinet, for sandblasting. Yes, HF has those as well, although often great deals can be had on these on craigslist. People don't tend to keep sandblasting equipment for some reason.
Another thing that's worth getting from HF is their storehouse assortments, like auto fuses, hose clamps, grease zerks, and O-rings. There's nothings quite so frustrating as being one small piddly items shy of completing a project, and having a good stock on hand pays off.
Agree with everything but the hose clamps, the metal is so soft , they'll strip out before they get tight enough to do any good..
   / Harbor Freight Tools that don't suck #3,232
>The F-style welding clamps are good as are the Vice Grip style locking c-clamps.<
They may be as good as ViCe Grip c-clams - but note - ViCe Grip is not the same as ViSe Grip. Different company, different quality.
Isnt a Vice Grip a form of self control?
X2. Even the ones at Home Depot suck.
   / Harbor Freight Tools that don't suck #3,235
No, the HF reels have never leaked and are several years old. The light blue one I made from scratch leaks, but it has a quick connect instead of a swivel. (It's quiet a bit cheaper.) It's no problem though, since I have a ball valve I turn off and on.
Graydog,
Thanks. I might get one and make the hoops out of 1/4". That's all my HF ring roller will handle.
   / Harbor Freight Tools that don't suck #3,236
Quick question on the Harbor Freight plastic laminator. I had planned to buy one and headed over there with $20 coupon in hand (I love a deal) and the wife asked what I planned to laminate. Well, I could only come up with two items. And since I don't need another piece of "stuff" around, I left empty handed.
Question is, could I just pick up a couple of those plastic lamination pouches and use an old iron to seal it up? Bad idea? Towering inferno of plastic?
9" Hot Laminator
Anyone with a hot plastic laminator know if the above would work?
   / Harbor Freight Tools that don't suck #3,237
   / Harbor Freight Tools that don't suck #3,238
It should work, but the plastic will stick to iron unless you lay something over the top to protect the iron. Parchment paper would do that but plastic may stick to the paper. Parchment paper is used for baking cookies, etc. Walmart has it. Good luck and don't ruin your wife's iron or you will wish you had bought the HF laminator.
Just a reminder, if you review a HF product, it helps to put the model number in the text of your post so that the thread is more searchable for the next guy.
Back to regular programming.
   / Harbor Freight Tools that don't suck #3,240
You can get laminations done at your local staples or office max. Its not very expensive and they can do large items, like poster board.
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
20 UTILITY TRAILER (A58214)
20 UTILITY TRAILER...
New Wolverine 84in 5way Skid Steer Scrap Blade (A59000)
New Wolverine 84in...
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2016 Ford F-150 XLT Pickup Truck, VIN: 1FTEX1EP4GFD61185, Extended Cab, 4 x 4, 2.7 L EcoBoost Gas (A59076)
2016 Ford F-150...
2011 Ford F450 Diesel with Just 156638 Miles (A56435)
2011 Ford F450...
