Harbor Freight Tools that don't suck
   / Harbor Freight Tools that don't suck #3,891
I had one of the "racing" jacks. Wouldn't buy it again. It was a quick pump and when lifting near it's limits it took a lot of force. It's one thing for a racing team to need to raise a car off the ground quickly but 4 or 5 pumps (vs 2) is fine by me.
Now that is a good point. I, too, noted on my 1.5 ton that it took more force when lifting near its limit of travel. Something to consider.
   / Harbor Freight Tools that don't suck #3,892
Diamond blade wet saw, $50. Works great and allowed me to do my whole bath ceramic tile project without renting any tools. Water tray is hard to remove without slopping water.
On the HF wet saw I found it is easier to have a fresh water 5 gallon bucket to set the sump in and a separate bucket to catch the used water in. It is easy to dump and no filter clog. This experience was gained after 10,000 clay pavers - and the saw still works great - used only 3 blades.
   / Harbor Freight Tools that don't suck #3,893
I was hoping, based on comments on here, that the little 900w 2-cycle generator would be a "don't suck", but now having had one for 6 months, I'm not too sure! I have used non-ethanol, fresh fuel in it exclusively, but it is almost impossible to start. If I remove the air cleaner cover and drizzle in a bit of fuel, it kicks right off. I shut off the fuel valve and run the carb dry whenever I am done using it. It seems to run ok after it starts. Maybe a little lean. So I'm suspecting something wrong in the choke/low speed carb circuit, or it may be that the fuel on/off valve is so restricted that it takes a long time to slowly drizzle a bowl full. Guess it's going back for a trade-in on another.
- Jay
   / Harbor Freight Tools that don't suck #3,894
- Jay
   / Harbor Freight Tools that don't suck #3,895
Interesting note relative to Harbor Freight. I happened to go into a Home Depot today and saw many Chinese tool products pretty much the same as Harbor Freight carries. Now, some were on sale but many items were cheaper than what they would cost at Harbor Freight.
Things I saw were cut-off tools, grinders, impact guns, hand tools and such. Surely this has to be having an effect on Harbor Freight?
   / Harbor Freight Tools that don't suck #3,896
HF...has a 4&1/2 inch grinder on sale right now for $12.00 and change...with a coupon even less but I think only good until this Friday...They have a reciprocating saw for only $19.00 ...again until Friday....I bought the grinder and will go this Friday and get the reciprocating saw...too cheap - I have to buy it...LOL
   / Harbor Freight Tools that don't suck #3,897
There are two recipro saws - a cheap one and a almost-tradesman one that has a higher amp rating (more power) and higher cost. I don't think I've ever seen the better one go on sale.
I have a couple of the $10 grinders. They are fine for occasional use and for running a wire brush.
   / Harbor Freight Tools that don't suck #3,898
Here is the one I am talking about...it is $19.99 with the coupon code...what do you think...? good deal or not...? Thanks
Reciprocating Saw w/ Rotating Handle
   / Harbor Freight Tools that don't suck #3,899
I don't have experience with either. In my experience HF power tools are generally less powerful than tradesman-quality tools (that cost more), so HF's more powerful choice will be more satisfactory. But their overall quality is improving, and now there are fewer dogs in their product lines.
In this particular case HF's Customer Reviews for each model should be a good guide. (and I see there are now 3 recipro saw models).
2003 McCormick XTX 185 XtraSpeed Tractor (A56435)
2003 McCormick XTX...
HUSQVARNA RIDING...
2002 Henderson 8X Mild X Sandspreader Attachment (A55973)
2002 Henderson 8X...
2012 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55973)
2012 International...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
John Deere 1025R (A53317)
John Deere 1025R...
