Hard arena sand
   / Hard arena sand #1
torlon2001
Minnesota
bobcat ct230
I have a sand horse arena (50x120) that has compacted over the years. I started with 4" of sand and added a second 3-4" a few years later. It's become increasing hard packed to where I can't get my 1 section drag to break it up. I have a Bobcat CT230 Compact Tractor (30 HP/5 ft wide) with a 1100 capacity 3 pt hitch. Is a disc harrow the best implement for me? I've been looking at the 6.5 foot (16-20-g) and 4 and 5 foot King Kutters since I'm only doing sand and would only use it once a year or so. Will a disc do the job...or is a tiller or other implement a better tool?? If a disc is right what type/brand do u recommend (cost is somewhat of a concern)? Thanks for any reply!
   / Hard arena sand #2
if you can control a disk depth, that will break up the crust but going to deep may pull up unwanted rocks and trash. same with a tiller. maybe an arena harrow or a spring tooth harrow would break it up. it might be worth bringing in another couple inches of fresh sand to work into it also.
   / Hard arena sand #3
   / Hard arena sand #4
my grandpa has 4 riding arenas, 3 of which are sand. He uses a scarfier on his bobcat skidsteer and a rotary rake to break down the dirt clods. His reasoning for the scarfier on the skidsteer is the down pressure. Down pressure is a key factor for digging on hard ground other wise you will find yourself adding a lot of weight to get it to dig in. does your FEL have the skidsteer quick attach?
   / Hard arena sand
No my FEL doesn't have the skidsteer quick attach. The scarfier is a good idea tho. I was thinking the 3 pt may offer some down pressure on a disc if I went with that type. The sand gets broken down into a powder and sets up super hard. Even if I load it up, my drag just skims across the top of the hard areas.
   / Hard arena sand #6
I'd be worried a disc would go too deep and mix sand and base material together. I think a box scraper scarifiers or C/S tine cultivator would work best to break up your compacted sand.
   / Hard arena sand #8
Can you get a more coarse material to mix in? I don't know where you live but around here 'decomposed granite' seems to be a material of choice as it doesn't really compact/set up hard.
   / Hard arena sand #9
A machine such as this John Deere 9 shank ripper would do the job at $695 + shipping. Ken Sweet
   / Hard arena sand #10
I have horses and have a sand/dirt round pen that gets hard over time. I use my box blade with the scarifiers set all the way down to bust it up and level it out. i am sure it takes me more trips around than it would using a implement designed for the task but it works.
   / Hard arena sand #11
Thi does sound like a job for a box blade, which also has many other uses, rather than a dedicated tool for once or twice a year.
   / Hard arena sand #12
Once or twice a year won't cut it. Folks that are serious about a soft arena work it two or more times per week, many do it daily.
BOSS MT 660 Fuel Trailer - 660 Gallon Mobile Diesel Tank, DOT-Approved (A55315)
BOSS MT 660 Fuel...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
UNUSED FUTURE SB45 EXCAVATOR HYD SILENT BREAKER (A60432)
UNUSED FUTURE SB45...
1977 Gleaner A630 Corn Head (A56436)
1977 Gleaner A630...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A61306)
2017 Yale GLC050VX...
