Has anyone built a TEMPORARY sunshade-canopy?
   / Has anyone built a TEMPORARY sunshade-canopy?
This is not as easy as it sounds. The umbrellas that clamp to the axle won't work because the tractors I have are too small and don't have sufficient clearance to mount brackets. Plus I'm not going to drill into my fenders. Further, the ROPS is in the way. The same is mostly true for the single pedestal umbrella with the addition most of the consumer reviews are negative.
I already have a big hat and after reading some replies am thinking an umbrella of some sort is the answer if I can figure out how to attach it. As noted, I could attach one umbrella to the ROPS side bar but it only covers half of me. Maybe I could put up two umbrellas meaning one on each side of the ROPS. Probably not great looking but I don't know how to hook just one umbrella to the center of the ROPS. that would work.
Thanks so far. Any pictures out there?
   / Has anyone built a TEMPORARY sunshade-canopy? #12
Look for an umbrella used for a deer stand, seriously. They are intended as a temporary roof for a ladder stand. I have a couple, I haven't tried it but they come with brackets that you could just zip tie or large hose clamps to your ROPS.
   / Has anyone built a TEMPORARY sunshade-canopy? #13
   / Has anyone built a TEMPORARY sunshade-canopy? #14
You could try using the rain fly from a small tent that has the small shock-corded fiberglass poles or one of the quick pop-up style sun shades they sell at Walgreens type places during the summer. Beach Cabanas, Tents and Sun Shades.
Steve
   / Has anyone built a TEMPORARY sunshade-canopy? #15
we added an umbrella to the kubota we use to bush hog. it's a piece of pvc that is clamped to the rear center of the tractor (where the slow implement sign used to be). when you need shade insert large umbrella remove hen done. this is the best picture of it, but you can see teh piece of pvc on in the center rear of the tractor
   / Has anyone built a TEMPORARY sunshade-canopy? #16
...most of the consumer reviews are negative.
Yes I saw that on several models. But I don't give much credence to someone who complains that an umbrella didn't stand up to a 35 mph wind. Really?
I have no experience with any of these current models, so maybe they really are junk. On the other hand, an umbrella is just an umbrella, not a rigid structure, so you have to have realistic expectations.
Terry
I used a beach umbrella on my 2520 last summer. It was one with the two piece shaft. I u bolted the lower part of the shaft to one arm of the ROPS. I then just slipped the top half in and out when I needed it. Only downfall was it was on one side of the ROPS so I would be in the shade in one direction and then in the sun headed back.
OK, thank you to everyone. I researched everything mentioned and here's what I'm going to do. If I can mount the PVC socket as shown in the photo above and also a large enough umbrella that shades me, I'm going to do that. It's a good plan that will take me 10 seconds to put up or take down.
Second choice--plan B--is to zip tie an umbrella to each side of the ROPS. Two umbrellas. This would work very well, I think, and provide adequate shade that can go up or down pretty quick.
Everyone should consider either a formal canopy if you can use it or certainly something temporary like we have talked about here. Considering the exposure to the sun that this sport and business involves, many of us are at risk of melanoma skin cancer. It's so deadly that a spot about the size of the head of a pin can have only an 80% survival rate and involve surgery that can take out two pounds of flesh. And that's if you're lucky.
Thanks again for the good posts and good advice. All of the ideas worked but these two work the best for me. :dog:
   / Has anyone built a TEMPORARY sunshade-canopy? #18
I thought I had posted this link in this thread, but it was another similar thread that I shared this link.
Haven't bought one (yet), but I am interested. Looks like this will work, and you can color coordinate :)
Tractor Umbrella
2002 Frieghtliner Pressure Digger Truck (A55973)
2002 Frieghtliner...
1762 (A58375)
1762 (A58375)
2013 Land Rover Range Rover Sport 4X4 SUV (A55853)
2013 Land Rover...
Deere 333G (A53317)
Deere 333G (A53317)
2020 DRAGON ESP...
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
