Has anyone made a chain/drag type harrow?
   / Has anyone made a chain/drag type harrow? #1
nyone
Elite Member
Ford 851
Im looking to make one if these type of ground tilling/ smoothing attachments for my ATV. It will be for light road smoothing and making food plots at a hunting lease. The land was logged about 8 yrs ago. The trails are old skidder roads, some un touched for 8 yrs. It will be left there, about 4 hrs away and i only get there about 3x a year.
I have a large pile of scrap steel and more than a few hours under my belt with a welder.
How does say 1/2in rebar hold up to getting drug across rocks and sand?
   / Has anyone made a chain/drag type harrow? #2
1/2" rebar and rocks = bent 1/2" rebar. Sand won't be a problem on it, it will take a while for it to wear out.
   / Has anyone made a chain/drag type harrow? #3
Well - I do not weld - so my "drag" is made of wood. It works just great - breaks up clods, smooths out tilled land, easy to pull - and, most importantly - raises a whole lot of dust. Notice - a set of large spikes across the front and same in the rear. I tow this abortion with a rope bridle attached to my ATV.
   / Has anyone made a chain/drag type harrow? #4
Welding rebar will make the rebar brittle which equals lots of breaking as you drag.
   / Has anyone made a chain/drag type harrow? #5
I don't need or use one but would a section of chain link fence work?
Im really looking for something to rip out weeds, and take off the high spots. If i could till it i would but i cant. So im prety much left with something i can tow behind an ATV without a motor.
   / Has anyone made a chain/drag type harrow? #7
I have about a 9 foot long section of 6 foot wide chain link fence, I have it folded over in half with a "T" post at fold and a length of chain attached about a foot in from ends of "T" post which forms a "V" and makes a loop at point of vee to hook on center shackel of draw bar.... If I need more weight I go over to the rock pile and put 4-5-6 fair sized rocks on it and drag away.... Also have about a 5 foot section of RR track with a couple of holed blown in each end to put chains through, and drag it when I need to knock gopher mounds or whatever down (also can be used on "chain link fence" harrow for weight)....
Dale
I have hurd that the chainlink ones get clogged up with grass/weeds and its almost impossible to clean out? Im working with 3/4ft weeds here. Of corse i will cut the big stuff down and most likely weed wack it. I dont have time to spray and burn. Im only there a week in the spring, a week in the fall and for hunting season.
Mabe i should just scrap this idea and hunt whats alreaty there.
   / Has anyone made a chain/drag type harrow? #9
About 4 or 5 sections of old railroad ties connected together by log chain will also work as a "bump leveler". You can add weight on top of the ties if necessary.
   / Has anyone made a chain/drag type harrow? #10
IF you are doing tall weeds I would think something like linked bars (angle iron/channel iron/pipe) would be better than chain or linked fencing harrow to knockdown tall stuff....
Dale
2014 Ford F-350 4x4 Ext. Cab Palfinger PSC4216 2 Ton Crane Service Truck (A60460)
2014 Ford F-350...
Wacker Neuson AR14H (A60462)
Wacker Neuson...
2001 Workhorse Custom Chassis P42 Delivery Truck (A59230)
2001 Workhorse...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A56438)
2006 Magnolia Dry...
Forklift (A56857)
Forklift (A56857)
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
