Having problems with Tractor Supply weed torch.
   / Having problems with Tractor Supply weed torch. #1
Brahmus
South Louisiana
Just picked up a Mr. Heater weed burner/torch, got home and hooked it up to 5lb bottle that was just filled. It's more of a match flame than a torch. I've played with both valves through both ranges and nothing. When I first strike it I get a little bit of torch action but only for a few seconds then it fizzles down. Am I doing something wrong or is this brand junk? Anyone have a suggestion for a better brand burner?
   / Having problems with Tractor Supply weed torch. #2
There's a safety shutoff valve in the hose that will shut down the flow of propane if it is too high, ie. should the hose get cut or burned in half. A lot of times when you first hook up the hose and open the valve on the tank, the rush of propane filling the hose is enough to trip this safety valve. Just wait a few minutes, and it should self-reset, and the torch should operate normally.
Also, you said 5 lb tank...that's a pretty small tank for the torch... you may have problems feeding the torch enough propane out of a tank that small... it's going to get very cold... you'll probably get better performance as well as run time from a 20lb tank.
Good luck with it!
must have been falling asleep, it is a 20lb tank. I'll crank it up today and see if the valve resets.
That was it. I cracked the valve slowly, if I opened it to fast I heard the valve shut. Never noticed this before, go figure. Now she's screaming, Thanks for the help Brian!
   / Having problems with Tractor Supply weed torch. #6
You're quite welcome!
   / Having problems with Tractor Supply weed torch. #7
I've never tried the torch route for weeds. How does it compare to roundup? Time to kill? How long does it last? How long does it take to cover an area? Cost?
Well I primarily got it to start my burn piles but I do intend to burn some weeds. The good thing is they are dead and gone that instant, no waiting and should last as long as roundup as both kill the plant there but don't prevent new plants from coming up. This torch was $60 and will probably last forever, not sure how fast I'll go through a bottle though.
   / Having problems with Tractor Supply weed torch. #9
Out my way we use both, but the torch is mostly for burn piles. I would say 50-60% of my weeds are poison oak. Roundup is the only way to go on that stuff.
   / Having problems with Tractor Supply weed torch. #10
Thanks for the info guys. I think for that money, I'll stick with my sprayer and Roundup. I have a gravel drive, about an eigth of a mile. Weeds on both sides plus turnaround areas.
   / Having problems with Tractor Supply weed torch. #11
One STRONG CAUTION! Do not use one of these on poison ivy, etc. The smoke will carry the itchy stuff through the air and maybe into your lungs. My wife in her ignorance burned poison ivy and was extremely sick for weeks.
   / Having problems with Tractor Supply weed torch. #12
I plan on getting one of these to use as a small flamethrower on tent catepillars that are in my apple orchard. I'll update with the results. Some critters have to learn the hard way.
2016 Ford Expedition XLT 4WD SUV (A59231)
2016 Ford...
2005 Detroit Diesel 100DSEJB 138kVA 3-Phase Diesel Generator (A59228)
2005 Detroit...
2008 Bobcat S250 Compact Wheel Loader Skid Steer (A59228)
2008 Bobcat S250...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
DEUTZ MARATHON...
SD Launch SDLB25 (A53317)
SD Launch SDLB25...
