Heating options
   / Heating options #1
Tomtint
Elite Member
Boston
L3700SU
We are finishing our walkout basement ( aprox 930 SF) and I'm deciding on how it is going to be heated. For starters, we have FHW by oil for the test of the house and I could add another zone for 2500.00 +\-. A 3 head Mitsubishi would provide heat and a/c for 5000.00 +/- and another option would be electric baseboards. The room will not be used everyday and is very well insulated now. Never drops below 50* even in the coldest days. Anyone have recommendations ?
   / Heating options #2
My house is built into a hillside. The oil fired boiler was/is in the basement. Heating upper two levels with wood insert in old fireplace. Now the the humidity in the basement is my biggest concern.
   / Heating options #3
Is the FHW Boiler in the same area? If it is, you could put in 20-30' of baseboard and cut into the return from your cooler areas like bedrooms so you get some heat down there. Since it's 50* all the time you aren't adding a lot if BTU to the boiler. This should cost maybe $300.
$2500 seems way out of line for a zone unless there is a lot of new piping and new manifolds and circulators involved, and you can buy a lot of electricity for that amount of money.
I have a office in a detached garage, 850 SF and have been heating that with a Monitor kerosene heater for years and considering changing to a split system heat pump for heat and cooling too when the Monitor dies, and seems these units are going to cost $2500-3000 plus installation likely nearly $4.5K but annual costs would be lower than the kerosene.
If you need AC and this can keep your house cool too then I would go the $5K route and with the most efficient units there is a tax credit too.
   / Heating options
Fortunately our basement is very dry. I put 16 mil plastic under the slab before it was poured and we sit on what amounts to perc sand. ( very good drainage) Any humidity could be knocked down very easy with a window ac for the few really bad weeks we get in the summer.
   / Heating options
The boiler is in the basement. Not in the same room but not far. I thought 2500 was high as well, maybe I should get a few more prices on it.
   / Heating options #6
The added loop sounds good. For your limited needs the electric might be the cheapest. You say the basement is dry but you might consider a heat recovery ventilator. In my basement it cut the summer humidity way down.
   / Heating options #7
With your 50 degree temps and limited use it sounds like electric baseboards would be pretty darned cost effective. I usually avoid them except in certain circumstances- I'd say this is one. I like the hydronic ones myself.
2022 CATERPILLAR D6XE LGP HIGH TRACK CRAWLER DOZER (A60429)
2022 CATERPILLAR...
2021 CATERPILLAR GP30N STRAIGHT MAST FORKLIFT (A60429)
2021 CATERPILLAR...
2013 Ditch Witch XT855 Tracked Loader (A56438)
2013 Ditch Witch...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2000 Freightliner FL112 S/A Day Cab Truck Tractor (A59230)
2000 Freightliner...
2006 Ford F-150 Lariat (A57148)
2006 Ford F-150...
