Help adjusting bush hog
/ Help adjusting bush hog #1
Nedfan
Beaumont, Tx.
Kubota B7800
Well, Im still new to this so bear with me. I have a Land Pride 5ft. Bush hog and I cut my hay field with it. I don't have the equipment for baling myself and I haven't found anyone who will bale it and give me a cut for the hay, so I cut it.
I need help setting the height on my bush hog. It's a rear discharge and I had a problem with bogging it down with too much grass, so I lowered my wheel a notch and even picked up the front so as to cut semi level. Now I can mow over ground which I have mown before with no problem, and I am now scalping the ground. At first I thought it was ant mounds, but I now realize it was simply the ground. Any tips on cutting more efficiently will be appreciated.
/ Help adjusting bush hog #2
The front should be a little lower than the rear for best cutting. Then set the height by adjusting the tail wheel and the 3-pt to achieve the desired height while maintaining the front low attitude. If the amount of cut material is more than the cutter can eject (as it too tall) raise the cutter until it can handle the material. You may have to cut twice to achieve your desired result.
/ Help adjusting bush hog #4
If it's scalping just on one side, you adjust the lift arm (on my two tractors, it's the right one that's been adjustable with a wrench) until both sides are the same height. Measure on a level spot on the pavement or in your garage.
Ralph
UNUSED KJ 3PC WIRE MESH (A62131)
UNUSED KJ 3PC WIRE...
2012 MACK Tender Truck w/ADAMS Rear Discharge Bed Auger (A63118)
2012 MACK Tender...
(INOP) 2017 FORD F550 XL SERVICE TRUCK (A62130)
(INOP) 2017 FORD...
UNUSED RAYTREE RMDM72S - 72" DRUM MULCHER (A62131)
UNUSED RAYTREE...
2023 John Deere X590 Lawn Mower (A63116)
2023 John Deere...
PALLET OF MISC FLOOR BUFFER FUEL DOLLY (A62131)
PALLET OF MISC...
