Rara Avis
Veteran Member
wmgeorge said:As a licensed master electrician, been a journeyman since 1970, I can tell you, IF the folks who write the National Electrical Code, even has the slightest thought Article 630 which covers Electric Welders was not correct or safe it would be changed. For a Arc welder (hobby) with 20% duty cycle at the highest setting, take the nameplate rating X .45 that is what the wire is sized on. For welders: Fuse or C/B shall not be rated at over 200% of the conductor ampere rating. (This does not factor in voltage drop for long runs of wire.)
Local codes may vary. Welding outlets are for welders and should be marked so, not for plugging your toaster into...![]()
I thought welders were plugged into the Dryer outlet...
