Gary Fowler
Super Star Member
- Joined
- Jun 23, 2008
- Messages
- 11,917
- Location
- Bismarck Arkansas
- Tractor
- 2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
The iron oxide (bluishish black patina on it) is the natural formation on steel when it is rolled and formed and it is pretty resistant to chemicals that work for making a patina. Acid is used to clean metal, not make it rust although if you leave it on and expose it to air it will rust up again. Acid will remove the iron oxide and phosphoric acid seems to do the best at cleaning carbon steel. Any salt added is going to make it rust and repeated wetting like wet boots will likely continue to rust as salt penetrates the pores in the steel and is very hard to remove. What ever concoction you use will need to be pressure washed really good to get all the salt and acid off.
Personally I would leave the iron oxide on it, maybe dent it up a bit with a chain but not a lot, take an awl and put some scratches in it like you would get from dragging a fire poker across it many times. TOO much hammering of the steel makes it look too fake at least in my opinion. Even after 100 years on the floor there will be more wear from walking (shining of the steel) than denting. I don't know of many folks who use their hearth for an anvil. There might be some minor scratches from the fire poker and some light(very light dents) but that would be about it.
