Help me identify this backhoe attachment
   / Help me identify this backhoe attachment #11
Newbie here....would the smoothness be affected by the hydraulics or the tolerances during manufacturing? What makes one backhoe smoother than another...
It can be a combination of things, most impotently, operator experience - but some hoes are inherently easier and smoother to operate than others because of their construction - valves etc. I've never operated a Long but it just seems a bit more difficult to control than most - based only on these two videos I've seen. I'm sure that with practice, the operation will be much smoother than in the video Bruce posted.
   / Help me identify this backhoe attachment #12
As three point hoes go, this one is fairly large with a long reach. That is useful. I also like the manual, one of the better ones out there actually - and now you'll have it. You may need to replace all the hoses, redo the seat and the cylinder seals may leak - it's obviously been sitting by itself for a while - that should be considered in deciding on a price. Hoses and fittings are costly - even if you have them done at NAPA instead of a dedicated hydraulics shop. Check on line for the price of TPH hoes, used and you'll get an idea if this is one you want for $1200. I do believe that price is north of what I would pay.
On the other hand, once you've had a hoe, you will never go back to a shovel - I love having one and find it useful for all sorts of tasks - including rear ballast for my 4n1 bucket.
   / Help me identify this backhoe attachment #13
The rods on the boom and dipper cylinders appear to be rusted. Others should be checked for rust. Rebuilding a cylinder can get expensive. No sense in replacing a seal if the rod is rusted.
I would agree with all of tyhe above. I will get some more information and take some more pictures and report back. Generally speaking, for those that have owned the Long backhoes have been satisfied.
   / Help me identify this backhoe attachment #15
Unless you want to do some rebuilding, I'd likely not pay more than $500 for it. You could need all of the cylinders rebuilt, plus new valves.
   / Help me identify this backhoe attachment #16
That was around the price I was thinking, might offend the owner/friend who thinks highly of it. One can pick up a used hoe in fair condition on Craigs List from time to time and they show up at auctions pretty regularly in the < $1000 range.
That would most certainly offend the family.
Thanks y'all.
I ended up purchasing this attachment, expect to start moving dirt in the next week or so. Total investment, including the purchase price is $2,300. I cant buy a new one for that, or one made with american steel with bushings. Im content i made the purchase. I eliminated the PTO pump and plan to run off the remotes on the tractor....i also replaced the control valve with a Walvoil (italian made) valve from surplus center. All hoses and fittings are discount hose supply.com of which i crimped and cut myself. I replaced the rods in the cylinders and repacked them myself.
20180311_180124 by Ben Burwinkel, on Flickr
20180312_203651 by Ben Burwinkel, on Flickr
20180313_182638 by Ben Burwinkel, on Flickr
20180315_211414 by Ben Burwinkel, on Flickr
20180317_161158 by Ben Burwinkel, on Flickr
20180317_174637 by Ben Burwinkel, on Flickr
20180331_104324 by Ben Burwinkel, on Flickr
20180331_135013 by Ben Burwinkel, on Flickr
20180331_104303 by Ben Burwinkel, on Flickr
20180331_104250 by Ben Burwinkel, on Flickr
   / Help me identify this backhoe attachment #19
Nice job looks great , Nice big shop you have:thumbsup:
   / Help me identify this backhoe attachment #20
Nice work on the rebuild, thanks for the pics!!!!
In Bruce's video I just watched the first minute. Couldn't stand to watch anymore of it. Operator doesn't understand the concept of a hoe.
I wouldn't like the seat swinging with the boom but I guess you'll get used to it. When your efficiency improves and you get faster that may be uncomfortable.
Anxious to hear your report on using the tractor hydraulics. I think that method is going to slow the hoe down a lot. Can't think your rear remote GPM is anywhere near what the PTO pump would produce. Hope I'm wrong.
Good luck with this project and report your progress!!!
When I saw the pic that included the front of your fridge I knew we shared a hobby. Then a couple farther down I saw your buggy. :)
UNUSED IRANCH SEMI-AUTOMATIC MINI QUICK COUPLER (A57193)
UNUSED IRANCH...
John Deere 2520 (A53317)
John Deere 2520...
2018 John Deere Z997R (A53317)
2018 John Deere...
UNUSED FUTURE FT-FR60 60" SIDE SHIFT FORKS (A57193)
UNUSED FUTURE...
UNUSED PAIR OF 76" SLIP ON FORK EXTENSIONS (A57193)
UNUSED PAIR OF 76"...
2020 Kubota SVL75-2 (A53317)
2020 Kubota...
