3-Point Hitch help please i have lost all hydraulic pressure on my MT1601D
   / help please i have lost all hydraulic pressure on my MT1601D
I'll guarantee you the problem is the pump. First ---the pump was rebuilt, they are not rebuildable. They are a throw away pump. Second ---You are using 80 gear oil. It works good when it is cold, but once it warms up it becomes thinner & quits working. third--, you have 2 separate systems & both are malfunctioning. What are the odds of both systems working & both quitting at the same time. You can put a pressure gauge on the bucket loader hose & dead head it. The valve has a relief valve. If it didn't you'd wreck the pump every time you extended the cylinders all the way. Surplus center has reasonably priced pressure gauges.
It is not the loader relief valve. You do not have power beyond so all the OUT flow is going to the 3 point if the relief is stuck open or closed. You would also need a malfunction in the 3 point system too.
Thanks again for your Information :)
i will try what you have suggested before and measure how much the pump deliverers in 1 minute :)
I have one Bulgarian Dealer in small tractors saying he has a functioning used Hydraulic Pump for my tractor (well being Bulgaria i must check it first so it fits), will buy that one if my Pump dont deliver the expected 12.5 liters/minute
   / help please i have lost all hydraulic pressure on my MT1601D #32
Thanks for your reply
Do you mean the large flat head screw on the Control valve inside the Hydraulic Block?
:( i didnt remove that one as well when i had it off and checked it , Bugger. :)
View attachment 557416View attachment 557417
Well I spoke too soon, worked for a day and then stopped, guess I gotta disassemble it again and see what's going on
exactly what mine did, works for a few hours after changing to new oil and fiddling with everything, then stops (well thats how it was) now its completely Dead :(
Let me know if you find the problem,
i am going to get the used pump from the Small tractor Dealer here in Bulgaria and see if that by any chance helps he wants 200€ (a fortune here in Bulgaria, for some its a Months wages)
   / help please i have lost all hydraulic pressure on my MT1601D #34
I don't think the pump is your issue, on mine I ran it with the lift cover propped up and watched to be sure the valve moved etc and oil flow never stopped coming from the return. If it was the pump not pushing oil it would have stopped or slowed, plus my loader works fine and it is in series ahead of the three point. Hopefully the new valve solves it, I'm confident the problem is within that valve
Well i gave up and have now ordered a new Pump, it will arrive in about a week, as nothing works on my MT 1601D nothing moves on the FEL or the 3 Point, i suspect it might be that the pump deliver oil but not enough to build up the pressure, if that dont help i will have to see if i can find a new valve for the Hydraulic Block. (Or a new Tractor :D )
   / help please i have lost all hydraulic pressure on my MT1601D #36
Relief valve sticking open when hot ?
The black oil is a mystery, is your crankcase oil level getting lower ?
Does this black oil smell burnt ? If it is actually burnt hydraulic oil, you have serious problems .
The oil is no longer Black after cleaning out all the black crap at the bottom of transmission, there was at least 1 - 2 cm of it. its clear and fine now. im sure that what happened was the screen on the filter broke and all the black crap mixed in with the oil.
I have now how ever tested the old Pump, it gave about 9 Liters at 1500 rev during 1 minute so im not so sure its the pump.
Bugger i just ordered a new one :) ah well good to have a spare.
Im close now to giving up :( Oil is flowing to the Hydraulic Block But nothing moves , just had the piston to lift arms out and no oil is coming in to the cylinder no matter what i do.
Oil is flowing to and from FEL but nothing moves.
There must be a fault in the Control valve in the Hydraulic Block that releases the oil before any pressure can be built any where. thats the only thing i can think of.
Ah well time to find an expert and have the tractor sent there so some one else can get grey hairs :)
   / help please i have lost all hydraulic pressure on my MT1601D #38
Ah well timer to find an expert and have the tractor sent there so some one else can get grey hairs :)
A stuck relief valve or a broken relief valve spring in your valve block will cause these issues .
Oil will just go back to tank and not do any work if this is the problem .
Is the relief valve an external adjustable type, which can be unscrewed from the block ?
Can you upload a picture ?
The FEL is connected on the side of the Hydraulic block (Where the external relief valve used to be)
And the return from FEL goes in to the Filler hole on Gearbox (that one gives oil all the time the tractor is running now, NOT sure but i think it didnt give oil in return unless i moved the leavers before)
34348703_1978094558867993_5111523961464684544_n.jpg34384008_1978094605534655_8316557063161380864_n.jpg34443335_1978094685534647_6278770973005053952_n.jpg34459612_1978094755534640_5890838527419088896_n.jpg34553473_1978094488868000_2919901978240745472_n.jpg
   / help please i have lost all hydraulic pressure on my MT1601D #40
"The FEL is connected on the side of the Hydraulic block (Where the external relief valve used to be)"
:eek:
Not even sure what to think about that, let alone saying something about that . LOL
2006 TK Equipment CM9 Towable Concrete Mixer (A55851)
2006 TK Equipment...
Uni-Carriers S1S1L15NV 3,000lb Electric Forklift (A55851)
Uni-Carriers...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
2018 Jeep Grand Cherokee SUV (A55853)
2018 Jeep Grand...
Toro Workman HDX-D Utility Cart (A53421)
Toro Workman HDX-D...
2012 VOLVO EC55C EXCAVATOR (A52706)
2012 VOLVO EC55C...
