Help Removing Knob
   / Help Removing Knob #11
Heat gun or hot water will do the trick. Most are a basic poly and press fitted on a flat shaft that has barbs to aid retention.
L.O.L., mine also falls off from time to time as a previous poster mentioned. Slip the claws of a hammer over the shaft and pull.
   / Help Removing Knob #12
Had to pull one of a BX last year and somebody had put adhesive on it, it was a pain to remove.
David Kb7uns
   / Help Removing Knob #13
There must be a women around there who has had experience with knobs...:p
heat gun or hair dryer will do the trick
Tried using a heat gun,worked like a charm.The knob came off with a good tug.I had to tap it back on so I don't think it will fall off.One thing to do is put a wet rag around the knob so as not to melt the plastic trim piece.
2005 TerraGator 8104 (A55302)
2005 TerraGator...
UNUSED FUTURE ML32 - 32" MINI HYD MULCHER (A52706)
UNUSED FUTURE ML32...
2021 UTILITY VS2DX 53FT DRY VAN (A59575)
2021 UTILITY VS2DX...
40' CONTAINER (A52706)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2019 KUBOTA U35-4 EXCAVATOR (A52706)
2019 KUBOTA U35-4...
