smiley
Platinum Member
A lot of good suggestions above but your project depends mostly on the lay of the land. If it's a sloping site or has an area 2 or 3 ft lower close by such as a stream, gully or highway ditch, it's pretty easy. Strip the topsoil/sod then dig parallel ditches from low to high end, with as narrow bucket as possible to minimize fill required, 12-14 ft apart. About 16-18" deep will suffice in most any climate. If necessary the ditch can start out deeper and decrease in depth if more fall is needed for drainage. As the ditch is dug place the excavated material 1/2 way between the ditches and grade it so it slopes toward the ditches, Roll between the ditches even if it's only done with the tractor/excavator/? then lay perforated 4" plastic or corrugated pipe with filter sock and "daylight" (run out the side of the slope) into the lower area/ditch or into a collector pipe that runs to the lower area. If you have a level site, you can do as Leonz suggested and put a tank in the center then grade so water runs to the tank, then pump it to a ditch where it can run off. Whatever method you have to use, unless it's very sandy or gravely, fill the ditches with and spread a few inches of locally obtainable suitable drainage material and top it with whatever your use requires. My neighbor built one a couple years ago and used run of bank in the ditches and screened gravel for the top.
Get at least 3 estimates and unless there's real extenuating circumstances, this is quite a simple job so don't let them talk you into fancy engineering drawings etc. With 40+ years of building of highways, parking lots, ball fields, tennis courts, running tracks etc and etc., I would guesstimate your contractor with proper equipment and trucking, should be able to lay it out and complete it in about 3 days .
