The TC40D does not have a clutch. All the Class III Hydrostatic tractors don't have a clutch. You just have two brake pedals on the left and two hydro pedals on the right. Life is so simple. /forums/images/graemlins/grin.gif
As far as the PTO goes. When you engage the the PTO on your tractor, you actually open a hydraulic valve that sends pressure inside your transmission to a PTO brake/clutch which uses hydraulic pressure to engage the PTO. When there is no pressure, the brake engages and stops PTO rotation. That's why you can't turn your PTO by hand when hooking up a rotary cutter or similar PTO-driven implement.
When you have and implement attached and start to engage your PTO, don't just push the handle up to engage, because you will probably pop a shearpin if you do that. That TC40 has "tons" of torque. First, put your engine at idle or below 1000 rpm. Next, slowly move the PTO lever toward engage until you just see the PTO shaft start to turn. Go a little further with the lever and let the PTO come up to speed, then fully engage the PTO. Now bring the tractor's rpm up to PTO speed and look for the green 540 light on the right side of your instrument panel. If you go too fast, the 600 rpm light will come on to tell you to slow the engine. About 2,600 rpm will give you exactly 540 rpm.
When you want to disengage the PTO, first bring the engine back to idle so the PTO speed slow and then disengage the PTO lever. If you disengage the PTO at full speed, it puts a lot of stress on your PTO brake which will stop the implement in about 3-5 seconds. Some guys with 6' or 7' rotary cutters have actually damaged their brakes this way.
These are things you won't really find in the Owner's Manual, and I'm sure other folks will have a lot of good tips for you too.
Enjoy! /forums/images/graemlins/cool.gif
