Help with top link adjustment for rotary cutter.
   / Help with top link adjustment for rotary cutter. #141
I suppose it does have that yellow plastic cover. If that was enough though then why all this worry about people getting wrapped up in the shafts? Actually, no, my slip clutch is out there spinning like a mofo with those long spring loaded bolts just wanting to grab something so a failed chain from the tailwheel to the top link could drop into a blender.
The chain from the tractor to the top link as posted could fail without getting wound up.
   / Help with top link adjustment for rotary cutter. #142
   / Help with top link adjustment for rotary cutter. #145
If you cut often in the type of terrain you're describing, you may want to use "check chains". Even though the lower arms would tend to let the front of the deck drop when you get to the bottom of a valley (exactly as you describe), the chains wouldn't let that happen, since they support the deck essentially at the rear tractor wheels, which is typically several feet forward of the lower arm position. As Mickey used to say, "Try it you'll like it!"
   / Help with top link adjustment for rotary cutter. #146
   / Help with top link adjustment for rotary cutter. #147
Describe "check chains" as to where would they attach and how are they used and adjusted? Are you talking about using chains to support the front of the cutter and not depending on the drag links?
   / Help with top link adjustment for rotary cutter. #148
   / Help with top link adjustment for rotary cutter. #149
Yes..
Soundguy
   / Help with top link adjustment for rotary cutter. #150
Yes..
Soundguy
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2019 CATERPILLAR 289D SKID STEER (A51242)
2019 CATERPILLAR...
2021 McFarlane IC-5140 Vertical Tillage Tool (A50657)
2021 McFarlane...
2000 PETERBILT 379 FLATBED TRUCK (INOPERABLE) (A50854)
2000 PETERBILT 379...
2022 TAKEUCHI TB2150 EXCAVATOR (A51242)
2022 TAKEUCHI...
