Before....actually it would still be possible to do it now. Because my lift pins were so high and I had the cutter too low, the runners dug into the ground and lifted the back of the cutter almost stright up, shearing the toplink pin. I keep the runners up higher now BECAUSE I lowered the pins so I could raise the cutter higher and still have enough lift to raise the cutter off the ground. I use to have to drag the cutter around with the tail wheel dragging. The top link chain is there because I sheared the second pin just by the acute angle of the cutter at the bottom of a steep hill. It did not flip up the second time but cut the pin any ways. I will take a picture.
