Here's why you grease your loader faithfully.
   / Here's why you grease your loader faithfully. #41
I have an old Model A ear tool for stubborn grease fittings.
It is similar to the chisel that you load with a teaspoon of grease, push is up against the fitting and smack the other end with the brass hammer... hasn't failed me yet.
No idea the psi a hammer smack would generate.
My manual grease gun is pistol grip and has two settings... volume on one and pressure when switched.
   / Here's why you grease your loader faithfully. #42
While reading another thread on this site I ran across this grease gun:
Amazon.com: G. Gun Grease Gun - The frustration-free Grease Gun - Quick and Easy greasing - 6.5ft flex hose standard - LockNLube Lock-on, Clip-off grease coupler fitted standard - Mess-free, Waste Free - Durable Industrial Strength Construction - Heavy-duty, 1�,��� psi Foot Operated Grease Gun - INCLUDES Shipping!: Automotive
Going to go back to my normal analysis paralysis mode now:eek:
OK, perhaps this (another discovery from a TBN thread) is really all I need (main problem is in holding the hose securely on zerks- if I go back to using my manual gun then this would probably be sufficient):
LockNLube | Grease Gun Coupler Tips. Free US Shipping.
   / Here's why you grease your loader faithfully. #43
That G gun looks cool but it is heavy and seems it would be a hassle moving it around. With a Lock n Lube I move around quickly greasing my machines. I think repositioning the G gun would slow me down.
   / Here's why you grease your loader faithfully. #44
bdog, from what I've read I believe that the advantages with the G.Gun are that you can hold a lot of grease (not sure anyone like changing cartridges and dealing with priming the guns) and that it doesn't require you to use weak/injured hands (that's the primary factor that someone had for getting one).
I wish that I'd heard about the LockNLube a long time ago. Not sure if this would solve my issue of trying to get the coupler on the horribly located fittings on my Kubota.
   / Here's why you grease your loader faithfully. #48
I think I'll give my wife a grease gun for her birthday, too.
And maybe she will buy a vacuum cleaner for you................ that has zerk fittings.:D
   / Here's why you grease your loader faithfully. #49
That vacuum better have some grease in it suitable for high speed. Those turbin fans in Vacuum's really spin fast. :laughing:
2022 Wacker Neuson LTV6 Towable Light Tower (A56857)
2022 Wacker Neuson...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2025 CFG H12R Mini Excavator (A56857)
2025 CFG H12R Mini...
14ft Tri Axle Homemade Trailer (A57453)
14ft Tri Axle...
2020 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2020 CATERPILLAR...
2019 John Deere 85G Midi Excavator (A56857)
2019 John Deere...
