Hi-lift blades for NH 60" 914A mm rear discharge
   / Hi-lift blades for NH 60" 914A mm rear discharge #31
Re: Hi-lift blades for NH 60\" 914A mm rear discharge
TC,
I am glad it worked out for you. You always worry some when you make a recomendation as to if the person is going to like it. Your lawn makes me envious from your pictures.
Thanks Murph
   / Hi-lift blades for NH 60" 914A mm rear discharge #32
Dang... nice yard! Glad you like them... I've enjoyed mine too...
Thanks...it took a lot of tractor seat time to get it that way. It also helps to have over a foot of 'black gold' farmland topsoil to grow in. /forums/images/graemlins/smirk.gif
The money side...the area with the stone wall...is only a year old. I tilled that side (about 60K sf) under and replanted it a year ago. I plan to do the same thing to the other half this fall.
My MMM is a rear discharge.
The only real concern I had, based on what you said, was mowing uphill on the slope part of my yard. It did so without a wimper. Here's a pic of the slope.
Thanks...
Just can't figure out what some of the guys don't like about them. The problems they had were not present here.
   / Hi-lift blades for NH 60" 914A mm rear discharge #36
Well- I found out my mystery with the gators. I got them online.. and I got the correct part number.
Take a look at the picture. I cant really blame the blades. Place I bought them online says they are the only ones that gator shows.
I boxed them back up and sent them back. I don't think gator makes the proper size for my cub cadet. left two stripes partially cut.
JP
   / Hi-lift blades for NH 60" 914A mm rear discharge #37
Yep... SHORT!!!
   / Hi-lift blades for NH 60" 914A mm rear discharge #38
The grass needs to be dry for gators to cut well. Up north in the cool season grass areas, spring and fall ,when the grass blades are succulent (full of water), you won't like the gators as well.
   / Hi-lift blades for NH 60" 914A mm rear discharge #39
I mowed the other night because I had to, the lawn was way long from a long period of rain. It was so wet I worried about my tires leaving ruts and my Gators cut great. No problems with wet grass here.
murph
2025 K4525 UNUSED Double Garage Steel Barn (A53117)
2025 K4525 UNUSED...
2011 VANGUARD 53x102 DRY VAN (A53426)
2011 VANGUARD...
2014 Chevrolet Tahoe SUV (A52377)
2014 Chevrolet...
2017 Hammerhead Off-Road Utility Cart (A51691)
2017 Hammerhead...
2011 Liebherr L586 Wheel Loader (A53473)
2011 Liebherr L586...
2007 FREIGHTLINER M2 BOX TRUCK (A53426)
2007 FREIGHTLINER...
