Home Depot Bulldog 700 4x4 UTV?
   / Home Depot Bulldog 700 4x4 UTV?
I was listening to the idle speed today and thinking it was too high. However, when it was really cold(single digits) it loped along at a lower idle. I looked in the manual and there is a cable adjustment section in there for the shifter. I agree, I will lower the idle speed first, then if that does not help I will adjust the cables before calling them.
   / Home Depot Bulldog 700 4x4 UTV? #92
I will tell you that if you adjust the idle to run at correct speed warm, it will have problems idling during the cold without some help of adjusting the choke and using the throttle to keep it running until warmed up a bit (it seems that the subaru air cooled engine was just that way). I started using Mobil syn 5W40 in it after the first 50 hours, seemed to crank and idle better in the cold weather.
BTW- your making me miss my trailwagon, it was easy to work on and did everything it was asked to do. My wife will never let me not own a RTV1100 with the cab now that she has claimed it, but even she misses the ease to driving the trailwagon around the property and on trails. :)
Good point, and it's really easy to set one idle for winter & another for summer. I just changed the oil & went with straight 30 full syn Royal Purple which is what the owners manual recommends(straight 30...it says nothing about Syn.) Then I read the subaru engine manual which stated 10-30 or 30w. One book says first change at 10 hrs the other 20...so I changed it at 15ish:thumbsup: Kinda wierd only putting in 1.55 quarts when doing a filter/oil change for a 653cc engine though...but that is exactly what it took.
Well Boys I put it through "trial(trail) by fire.....an no it did NOT catch on fire:laughing:
I trailered the Bulldog to a 144 ac tract that my wife is listing for sale. I met a friend of the owners that was going to show me the features and boundary lines. Turns out he is a logger and logged it 8 years ago. Some of the old skidder trails were steep......well over 30 degrees steep and washed out with 2' deep ruts. We still have snow melting, so everything was damp to wet even though the sun was out.
So I pointed the Bulldog up the inclines and it went...it did not spin a tire unless that tire was not touching the ground. It hauled 500 lbs worth of men right up with no issues at all. I did slide off into one rut and both right side wheels came off the gound by about a foot.....backed back down out of it ok.
Here is a pic of the trail up...the pic does not do it justice...this is STEEP:
Then down...notice you can not see the bottom real well due to the slope?:
So, at this point I'm thinking..."this thing really can go where an atv can go". Btw, I ride an enduro/dual sport, and have owned atv's for 12ish years, so I am intimately familiar with the steep trails of East TN and know my way around off the beaten path. Anyway, my confidence went from 100% to about 7% when after taking pic's that the top we turned around to start downhill......down....hill. Brakes would not hold it, so I applied the emergency brakes and used them to help out. I still could not slow enough to be comfortable, and thoughts of a Luge tube ran through my pea brain....except instead of being in a light sled, I was on a 1,000lb sled with 500 extra lbs of man fat. Soooo, yep it was Mr Toad's Wild Ride down that there mountain. There were three Black Daimond runs about 100 yrds each and all of them had my passenger and I white knuckling and laughing nervously.
It was NOT fun, and looking back it was a stupid choice on my part to even go up that kind of trail in this kind of machine. I managed to stay out of the ruts which would have flipped us, and to not hit a tree or boulder(there were many) and negotiated all three runs without mishap....well except for the now missing 8 out of my nine lives. Older and wiser?...not so much yesterday:duh:
So after we got down on level dround I noticed the brakes were gone...pedal to floor. I was not surprised since I was pushing so hard on that pedal my thigh muscle went into de-fib several times. My passenger even said he was helping over on the other floorboard mashing that invisible brake pedal. Anyway, I looked at it later in the afternoon and the fluid level was way down in the master cylinder reservoir. So I filled it and started bleeding them all the way around. Air in the fronts...rear was fine.....hmmmm. After 30 min I finally saw a drop fall off the passenger caliper when under pressure. Yep, banjo nut was loose and leaking. Tightned it, finished bleeding and it seems fine. And, no I am not going back up there to see if the brakes would now hold ....nope never again:pullinghair:
Other than the minor brake issue, I really don't think any other UTV could have done any better especially being piloted by a "man a that didn't know his limitations.........":cool:
Trama Teaches.........
   / Home Depot Bulldog 700 4x4 UTV? #95
Glad you made it back down safely! I imagine it was quite a ride.
I do think your Bulldog would have been fine on that had the brakes been working properly. I know either of my Rangers would have been fine going up or down that.
I wonder how good the stock brake pads are on the Bulldog? Maybe you could find some better replacements.
I do think you ought to find some place with a similar slope with a clear runoff at the bottom where you can safely test how well the brakes will hold on a slope when they are working well. If for no other reason but to restore your confidence in the machine.
   / Home Depot Bulldog 700 4x4 UTV? #96
Oh, come on, you NEED to know. I couldn't sleep wondering if it's fixed, you need to find out before you get old and another incident like this causes the old ticker to stop.:laughing::laughing:
   / Home Depot Bulldog 700 4x4 UTV? #97
7
sounds like you're giving free joy rides
around here the carnies get a couple bucks a ride :laughing:
hey man stay safe but do have some fun :thumbsup:
   / Home Depot Bulldog 700 4x4 UTV? #98
I know it wasn't funny coming down, but I laughed my butt off reading your description of it.
   / Home Depot Bulldog 700 4x4 UTV? #99
You gotta try again somewhere, you may need good brakes in a pinch someday. Maybe the pads are super cheesy or it was just the fluid issue. You could add a boat anchor to the rig. :D
Actually, I thought about a boat anchor..................or a parachute:muttering:
No{shudder}, and I will have to go back and show this property to clients after she gets the listing done. I will bring a 10' stick of 1/2" EMT and a 24" level so I can verify the degree of those slopes and post them up here....I will do this on foot of course:thumbsup:
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
New/Unused Self Dumping Hopper (A51573)
New/Unused Self...
2005 Chevrolet Colorado 4x4 Pickup Truck (A51692)
2005 Chevrolet...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A53472)
2021 John Deere...
2017 John Deere 9620R Scraper Special Tractor (A53342)
2017 John Deere...
