Homemade Articulated Mechanical Thumb
   / Homemade Articulated Mechanical Thumb #71
Looks great, Rob. I see you completely avoided the metric pin
and hole issue by avoiding the use of any of the existing bkt
linkage holes.
Nice OP welds, too. If I could do those, I would not be removing
my dipper sticks to weld on my brackets.
Unfortunately, I could not view your video as I do not have the
Flash 8 s/w. Will your new video use WMV or MPG file formats?
Hi Dave, thanks for the compliments.
Yes, you are right. I made sure to avoid the Metric stuff. Keeping the linkage SAE means easily replacing worn parts. Sorry you could not view the videos. They're out of my Nikon "Coolpix" camera. The movement bears out what you discovered in your wooden model. I'll send you an email and maybe Loretta can convert the files for you to view?
   / Homemade Articulated Mechanical Thumb #73
3RRL said:
Bro,
Electrical short somewhere ... Most probably between my ears though.:)
I had one of those once too. There was a twig holding the PTO cable just a hair off the stop. The safety switch was activated and the tractor wouldn't start. I didn't diddle with the PTO lever as I could plainly see that it was in the "off" position. (DUH!) Now I know. Have also had issue with "stuff" under the HST peddle keeping it from starting. Double check all levers, peddles, clutch, seat switch etc. Dumb stuff is usually cheaper to fix than broken stuff.
jb
Dave,
I was wondering if you ever got you video of your mechanical thumb uploaded? I'd sure like to see how yours is working.
I'm going up to the property this weekend with my friend gugloils who is going to diagnose the electrical problem. He is flying in from New Mexico just to help me...can you believe that? Hopefully, he will find the problem and fix it. When I get the tractor running, the first thing I'm gonna do will be to test my thumb out. I'll be posting more photos and videos of it at work.
Keep your fingers crossed for me.
   / Homemade Articulated Mechanical Thumb #75
3RRL said:
Dave,
WOW ! He must really want to see that thumb work:)
   / Homemade Articulated Mechanical Thumb #76
3RRL said:
Dave,
I can't see uploading it at all, given my limitation to dialup access. If I
put it on YouTube, it would take a while. Verizon has promised DSL for
years, but I am not holding my breath.
As for those electrical gremlins, I notice that mice will nest in any tractor
not stored in a "secure" building. They seem to chew wires just for the
h3ll of it. Rain in the starter switch had been a problem, too. My Kioti
stays indoors and has only one interlock switch, thankfully. My JD is under
a carport (tractorport?) and regularly gets mice and recalcitrant interlock
switch gremlins.
As for my articulated thumb, it has been fantastic. I have been digging
up old pipes and implements for recycling and it has worked flawlessly. I
can see my plowshare thumb tip is harder than my cast steel hoe teeth as
it has made quite an impression in the middle tooth.
As promised, my good friend Larry (guglioLS) fixed my electrical problem in a jiffy so the first thing we did is remove the boxblade and mount the Nardi Backhoe on the tractor. I had told you guys before that the home made subframe was kinda a tight fit, but it usually takes me 10 or 15 minutes to get it on. With Larry helping, it only took about an hour. :D
He had his side completely pinned and mine wasn't in yet, and there's not enough play in the fits to allow that. So he and I were muscling the backhoe and subframe to get it in and connected. We finally got it on and off we went to test out the mechanical thumb.
Larry had the honors.
I'm hoping for his comments about the performance of the thumb too.
Rob-
Here is a picture of the Kama with Grapples and Mechanical Thumb taken in the field near our food plot.
Just before that, Loretta took a video of how the mechanical thumb worked under power. Here I am checking it out while Larry operates the controls. It is working just as I was hoping it would.
Now to try it out.
The next step was to try it on some real rocks and logs. So again, Larry worked it for the first time ever.
Here he is trying to get used to my backhoe movements, and using the mechanical moving thumb.
Just before that, he also had a chance to try out the dual grapple set up on the massive bucket. This was the first time he had operated the tractor and the backhoe.
Larry owns a beautiful Jinma 354 and has made all kinds of mods and improvements to it. So he is no stranger to hard work. He did comment on how stable the Kama 554 was with loaded tires, and that it has a lot of power, although he did not do any really heavy digging with it.
Then it was time to see if the backhoe could pick up that frozen water laden log.
This is a photo of it.
And here is a video. The log is super heavy and was a bit too much for the Nardi.
As a matter of fact, when it was my turn to try out the backhoe thumb, I tried to get that big log (of course). I managed to test it to failure and tweak the jaws plus a couple of links ... crap! :(
1964 Mercedes-Benz 190D Car Sedan (A56859)
1964 Mercedes-Benz...
1991 International 4900 Box Truck (A55315)
1991 International...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
202476 (A54757)
202476 (A54757)
2013 PETERBILT 389 (INOPERABLE) (A55745)
2013 PETERBILT 389...
2017 Ford F-550 4x4 Crew Cab Stellar 7628 7,500lb. 3.75 Ton Crane Service Truck (A55973)
2017 Ford F-550...
