Gale Hawkins
Super Star Member
- Joined
- Sep 20, 2009
- Messages
- 12,426
- Location
- Murray, KY
- Tractor
- 1948 Allis Chambers Model B 1976 265 MF / 1983 JD 310B Backhoe / 1966 Ford 3000 Diesel / 1980 3600 Diesel
Yes I made the bucket edge.
It is for snowplowing. 2 layers of 3/8" steel stich welded together.
I will remove the bottom one when it is heavily worn and add a new strip.
I will most likely make a tooth bar later but will try and find high carbon steel for that and the cutting teeth.
That is smart. I wondered why you would duplicate the cutting edge but having a soft one to wear during snow removal is a great plan. After snapping ours last spring I found ($$$) a 3/4" x 8" cutter bar that would reach edge to edge and had my shop cut out the old on an put on the new one. Now I have to be careful or I will gap the ground because the new one digs so well.
