Aug 10, 2013 / Homemade dingo brush cutter #1 M Msc2177 New member Joined Aug 2, 2013 Messages 10 Location Blue ridge ga Tractor Toro dingo tx425 I am building a 42" bush hog for my dingo tx425. It will have a 5.9 ci hydraulic motor Going thru a 40 hp 1:1 gearbox. Attachments image.jpg 586.1 KB · Views: 2,596 image.jpg 548 KB · Views: 3,050 image.jpg 443.6 KB · Views: 2,197 image.jpg 602.5 KB · Views: 1,458
Aug 10, 2013 / Homemade dingo brush cutter Thread Starter #2 OP M Msc2177 New member Joined Aug 2, 2013 Messages 10 Location Blue ridge ga Tractor Toro dingo tx425 A few more pics. I put hinges at the top of quick attach for mowing up slopes Attachments image.jpg 921.3 KB · Views: 1,665 image.jpg 561 KB · Views: 736 image.jpg 770.6 KB · Views: 2,950
Aug 10, 2013 / Homemade dingo brush cutter #3 S stuckmotor Super Member Joined Sep 23, 2009 Messages 5,292 Location Lower Up State S.C. Tractor AC WD 34 hp/3500 lbs MF 261 60 hp/5380 lbs Cool! What hydraulic flow rate does the motor require?
Aug 10, 2013 / Homemade dingo brush cutter #4 B Brad_Blazer Veteran Member Joined Aug 19, 2004 Messages 1,870 Location Caldwell Co. NC Tractor 2006 Kama554; 92 Belarus 250AS Pretty sweet so far. Are you going to have a pair of castors or skids at the front to limit the cut?
Aug 10, 2013 / Homemade dingo brush cutter Thread Starter #5 OP M Msc2177 New member Joined Aug 2, 2013 Messages 10 Location Blue ridge ga Tractor Toro dingo tx425 It is rated for 15.8 but my machine only puts out 11gpm. It should still turn 550rpms
Aug 10, 2013 / Homemade dingo brush cutter #6 DT86 Elite Member Joined Dec 19, 2010 Messages 3,944 Location VA Tractor Kubota Looks great! I've never seen a mower on a Dingo or the like but it looks like a great idea. Just don't hit any yellow jackets.
Aug 10, 2013 / Homemade dingo brush cutter Thread Starter #7 OP M Msc2177 New member Joined Aug 2, 2013 Messages 10 Location Blue ridge ga Tractor Toro dingo tx425 I will put 3" flat bar along the bottom for skids. Not sure if I'll need the castors yet.
Aug 10, 2013 / Homemade dingo brush cutter #8 A Arc weld Veteran Member Joined Mar 23, 2013 Messages 1,875 Location Edmonton, Alberta Tractor MF 135 Will you need to install a hyd. oil cooler for continuous operation?
Aug 10, 2013 / Homemade dingo brush cutter Thread Starter #9 OP M Msc2177 New member Joined Aug 2, 2013 Messages 10 Location Blue ridge ga Tractor Toro dingo tx425 I don't believe I'll need an extra cooler. A lot of dingo attachments are built for continuous use. It has a cooler now with an electric fan mounted to it.
Aug 10, 2013 / Homemade dingo brush cutter #10 Scooby074 Super Member Joined Aug 4, 2006 Messages 6,152 Location Nova Scotia Tractor BX 25, ZD 326 nice project :thumbsup:
