Homemade snow plow mount?
   / Homemade snow plow mount? #1
Mattsy Fergy
Erie PA
GC1705
I'm too cheap to buy the $1800+ snow plow for my 1705, so I'm thinking about building a mount, and buying a used plow. I did find a nice 6.5' poly plow setup locally, off a Jeep, for a good price, just needs mounted to the tractor.
I thought the mounts should be along the side of the frame, but everything I see has them at the front.
Pro's/cons? Pics of yours.
Initially I wanted to mount it to the bucket, but hearing about the possibility of "tweaking" the loader arms when the ground or snow piles freeze, scared me off from that. I don't need to bend those arms.
I went ahead and bought one of these; Reversible Snow Plow | Van, Truck & SUV Snow Plows | SNOWSPORT 18 I found a 66" one, slightly used, for a good price.
I am planning to mount a 4x4 crossways at the back end of the hitch, and set it in the bucket, with a center chain to hold in place.
That way it should kick out if I catch something with the corner, and I can remove it quickly, when I need the bucket.
This will handle the under 6" "annoyance" snows we get often, and the rubber edge should protect my grass and driveway.
i know it's useless for back dragging, but I don't do much of that, and I still have the bucket. I may start looking for a back blade.
Dealer wants $2500 for a tractor mount, and when I need the bucket I would have to spend half an hour switching then out.
   / Homemade snow plow mount? #3
I attach my 7'6" snowplow to bucket on both Kubota's over the years never had problem,I pay attention hard objects also frozen banks etc.
   / Homemade snow plow mount? #4
And make sure the trip springs are working.
   / Homemade snow plow mount? #5
Yes, there is some risk involved in using a loader mounted plow. There is some risk every time you use your tractor, including with a frame mounted plow.
If your plow is sprung properly, and you use some common sense, you should have no trouble. The loader arms handle driving the bucket deep into the ground, and hitting rocks.
Mark, or remove any possible hazards, and you should have no trouble.
You also don't need to go fast, when you push snow. I can crawl along, with a mountain in front of me. If you are going slow, you won't damage anything.
A loader mounted plow is much more versatile, than a frame mounted plow.
I removed the bucket, and created a frame to attach the plow. It is hinged, to allow the plow to float. And, the pivot point, needs some slop to allow the ends of the plow to raise, or lower to follow the terrain. That takes most of the stress off the loader.
I have used this for 10 years now, without any issues.
   / Homemade snow plow mount? #6
Been using this setup for over 20 years. Loader hydraulics for up/down swing left and right. I set the plow frame pickup points to be the same height as they would be on a truck mount.90402086.jpgPIC00013.JPGPIC00011.JPG
Maybe I will repaint it this year...
   / Homemade snow plow mount? #7
   / Homemade snow plow mount? #8
I had a Snowsport plow that I could run in the front receiver hitches on my Boomer and RTV900. I traded those units in on a Toolcat so I will try it on the front or rear...whatever works best.
I'll have to get a pic up of the mount.
   / Homemade snow plow mount? #10
Was just wondering same thing for my GC2410....I have a 60 inch moose ATV plow I have used in 8 years. Was going to sell it but if i could somehow mount it to my loader bucket I would have an awesome snow machine t go with my 60 rear snowblower. Any thought on how to mount this with out destroying or cutting either the snow plow or bucket?
2023 Kubota BX1880V-1 Sub - Compact Utility Tractor with 54-Inch Mower Deck (A55314)
2023 Kubota...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A57024)
2016 KBH...
2012 AMERITRAIL (A55745)
2012 AMERITRAIL...
Truck Metal Cargo Storage Box (A55788)
Truck Metal Cargo...
JOHN DEERE 608C LOT NUMBER 19 (A53084)
JOHN DEERE 608C...
JOHN DEERE XUV590M LOT NUMBER 27 (A53084)
JOHN DEERE XUV590M...
