Rotary Cutter Hookin' Up That Rotary Cutter
   / Hookin' Up That Rotary Cutter #1
Harv
Elite Member
California - S.F. East Bay & Sierra foothills
Kubota L2500DT Standard Transmission
Hookin\' Up That Rotary Cutter
I haven't used my rotary cutter as much as I'd like to, mostly 'cuz I'm always pressed for time up at the property, and hooking up the PTO shaft has always been a trying experience. On Father's Day, however, I thought it through a little bit and figured out a way to lessen the hassle.
Now, keep in mind that I'm still pretty much a newbie with this sort of thing, but I'm curious if any of you out there first of all have had the same trouble, and second of all have resorted to similar tactics. It comes down to the plain ol' awkwardness of dealing with a heavy hunk o' iron (shaft) which is in a position that you can't reach very well. My previous approach was like this:
- Position tractor to cutter.
- Reach in from the side as best I can and lift the shaft to PTO height with one hand.
- Retract snap ring collar with the other hand.
- Use extra hand to keep myself from falling over.
- Turn PTO shaft with another hand until splines match up.
- Use two more hands to push shaft firmly onto spline.
- Something ain't lined up quite right, so nothing happens. Back and arms are complaining.
- Back it off, put shaft down, straighten up my back and shake out the arms.
- Repeat whole process until the yoke snaps onto PTO spline (3 or 4 attempts on average)
Fact is, I don't really have that many hands, so I make up the difference with a lot of creative language that I hope my children never have to hear. /w3tcompact/icons/tongue.gif
Okay, so after studying the situation, I figure that I should be able to eliminate almost all of the back pain and get by with several fewer hands if I could just plant one foot on either side of the shaft. This position would also put me directly behind the PTO, making alignment much easier. The problem, of course, is that the 3-pt arms, the cutter deck and that annoying mast are right where I want to be. And they sort of need to be there.
The solution? Let go of my dignity and self esteem and just mount this sucker like it was a mechanical bull. The attached pictures tell the story. It's a little hard on the keister (I'm seriously considering some kind of saddle), but I got the PTO shaft on and off smoothly and easily in a matter of seconds. Dignity be danged. /w3tcompact/icons/grin.gif
This may be much ado about nothing to most of you, but I'd like to hear from anyone who has found this kind of hookup more of a chore than you'd like it to be.
   / Hookin' Up That Rotary Cutter #2
Re: Hookin\' Up That Rotary Cutter
Actualy, Harv...that's the way I do it too.
See, my friend...you are not alone!!
   / Hookin' Up That Rotary Cutter #3
Gee I like your posts Harv.
Haven't see a newie for a while and it is refreshing to see someone tell it as it is !!
My slasher is only 4' wide and I can get to the shaft from the side.
Also being an oldie, I don't have the PTO covers etc. like you appear to have so things are a lot easier for me to do.
From what I have learned on TBN, very little to do with tractors has anything to do with ease, cleanliness or ergonomics /w3tcompact/icons/laugh.gif
Cheers
   / Hookin' Up That Rotary Cutter #4
As a moderator one, should never have to use language that a child shouldn't hear. However as on old sailor, apparently I've occasionally been heard to use language not appropriate for neither grownups or children.
   / Hookin' Up That Rotary Cutter #5
Very interesting, Harv./w3tcompact/icons/laugh.gif I think you should never argue with success; whatever works./w3tcompact/icons/grin.gif But for me, your previous method, minus about half the steps, only took a few seconds. Maybe it was because my rotary cutter had the pin instead of the collar./w3tcompact/icons/laugh.gif
   / Hookin' Up That Rotary Cutter #6
Great idea, and I will give that a try. Maybe instead of a saddle, something like a swing board with a short loop of rope that will hang over the top lift point and give the rear some additional support. Or just a 1 x 6 board with bolts at each end to keep it from sliding down the arms you are sitting on would work too.
I feel your pain in that description all too well.
   / Hookin' Up That Rotary Cutter #7
Harv,
I do it two different ways. 1-Lift the 3pt up with cutter attached, lines the PTO shaft and usually slips right on. 2-Take the shear pin out(see from pic thats kind you have), pull shaft off, collapse shaft, put on tractor, extend shaft and put back on cutter and shear bolt back in. These methods make hooking my cutter up alot quieter (less cuss words). /w3tcompact/icons/grin.gif
Hope this helps.
   / Hookin' Up That Rotary Cutter #8
I am a city raised boy married to a farm girl for thirty six years. I always have trouble with the PTO hook-up for our bush hog. My solution is just to call my wife. I hold the weight and she lines it up and snaps the ring in place. The truth is she can do it without my help but she lets me feel helpful.
The best fun was when I shopped for the 4300 and spent three months learning from this site and anyone that would answer my questions. I finally decided on the Deere and took my wife to look at it. She had told me to do the research and just let her drive it before I signed anything. We were headed to dinner and Jane had on a dress and heels. We were in a hurry so when the salesman handed me the key, I just gave them to her. The salesman was in total shock as she started the tractor and ran it around the yard and even filled the bucket with dirt from a pile and played with it. She got the attention of the service department and they were all in the door watching her put the tractor through her inspection. She got off and told me she liked it and that we were going to be late for dinner. As I handed the keys to the salesman, a young man from the service bay called out and asked if we had any daughters.
   / Hookin' Up That Rotary Cutter #9
<font color=blue>...Take the shear pin out... and shear bolt back in. ...</font color=blue>
I don't understand...? What side of the drive shaft are you disconnecting... the tractor or the implement side...?
Basically... all three point implements are hooked up in the same order:
(try to get into a standard routine for all of them with little variation)
1)Hook up left lift arm first
2)Right lift arm next (you can now adjust height up/down if you have to)
3)Slide driveshaft yoke on tractor's PTO spline and lock
4)Toplink last (so it's out of your way while doing the rest) and adjust accordingly... (toplinks are cheap $15-17... you may leave attached to implement and have already pre-adjusted)
Shear pins and slip clutches are always on "implement" side...
Overrunning clutches on "tractor" side...(unless combo slip/overrun on impl.)
You grab the driveshaft yoke with both hands (like you're ringing somebody's neck /w3tcompact/icons/blush.gif) and slowing twist in one direction or another while sliding the yoke onto the tractor spline... (with practice... shaft hookup is usually seconds...)/w3tcompact/icons/smile.gif
   / Hookin' Up That Rotary Cutter #10
I have to say that on my 165 there is plenty of room to work on either side of the hitch to hook up lift arms and PTO. But, the compacts and sub compacts create a new challenge. In some cases, it's like eating an elephant through a picket fence. Plus, the smaller the tractor and larger the cutter the tougher the job gets.
In your experience, does adding a quick hitch make the job (hooking up PTO) tougher?
Roy -
Glad to hear I'm not alone. Now there's at least two of us with no dignity. /w3tcompact/icons/laugh.gif
Neil -
<font color=blue>very little to do with tractors has anything to do with ease, cleanliness or ergonomics</font color=blue>
Yeah, it's quite a stretch for a lifetime computer geek like me.
Bird --
I'm sure you're more adept than I am at all things mechanical, but I wonder if the slightly smaller size of your tractor made it any easier. As I recall, you had the exact same cutter that I have.
Hmmm... /w3tcompact/icons/hmm.gif Another thought that might explain it -- when you walk, do your knuckles drag on the ground? /w3tcompact/icons/grin.gif
Wally -
Disconnecting the shaft at the cutter end is something I had not thought of. Seems like an extra step, but I can see where it would make it easier. I never raised the cutter to PTO height, either. Guess I haven't been very creative. Thanks for the input.
Tim -
Your profile doesn't say, but I'm guessing you're too far away for me to borrow your wife whenever I need to do some brush hogging. I liked your story, though.
John -
Your procedure reads just like my manual, but that procedure just plain doesn't work for me. Could be because those extra hands I have are nothing but thumbs. /w3tcompact/icons/tongue.gif
Jim -
Sounds like you've got some seriously big equipment, which could very well make the difference. I like that better than admitting I'm just a clutz.
Wow! I didn't start out to reply to each and every post here, but y'all had such good things to say.
   / Hookin' Up That Rotary Cutter #12
ON THE NH 1630 THE PTO SHIELD LIFTS UP SO YOU CAN GET AT THE SHAFT AND THE TRACTOR SHAFT WILL SPIN SO THE HOOKUP IS QUITE EASY
   / Hookin' Up That Rotary Cutter #13
Of everything I've hitched up, the rotary cutter is the most difficult to deal with. It's so darn heavy and only has one wheel. The RFM's have 4 wheels and scraper blades are light enough to manhandle, lift boom is a featherweight, etc.
The least hassle hooking up the rotary cutter was when I used the FEL to inch the tractor for and aft to get the arms connected. I first connect the lift arms. Just stand the bucket on edge and the "curl" / "dump" control gives you extremely fine control. Of course the engine was stopped before fooling around with the PTO.
With the arms connected, the PTO shaft doesn't need to extend beyond the normal operating length. It could end up being more difficult to deal with if there is some wear or a rough spot that affects pulling the shaft to extend it............chim
   / Hookin' Up That Rotary Cutter #14
<font color=blue>when you walk, do your knuckles drag on the ground?</font color=blue>
/w3tcompact/icons/laugh.gifAt my age, there's a number of things startin' to drag, but it ain't because of the length of my arms./w3tcompact/icons/wink.gif
   / Hookin' Up That Rotary Cutter #15
<font color=blue>Of everything I've hitched up, the rotary cutter is the most difficult to deal with. </font color=blue>
I felt the same way until I figured out a 4' long 2x6 solved everything. I just back the tractor up to the cutter and drop the arms on top of the pins fairly close to alignment. Then I hop off, grab the 2x6, slip it under the front of the deck, and move the deck until the pins align, and I am done. No more pushing, kicking, and calling it pet names./w3tcompact/icons/smile.gif
   / Hookin' Up That Rotary Cutter #16
I agree, Harv. Telescoping links on my TC25D make hooking up the 3ph rather rather easy. It's hooking up the drive shaft to the PTO that is difficult, primarily because you're pulling back on the collar at the same time you're pushing forward on the shaft to slip it over the PTO. Add in the safety shield on the drive shaft and it's a recipe for frustration! Do all rotary cutters have the collars? Do any have the push button type like my post hole digger?
   / Hookin' Up That Rotary Cutter #17
The locking device on PTO's is dependent on the manufacturer. The most poular methods are the locking collar and the spring loaded pin. There are others as well, but at least in our area, are not seen as often.
   / Hookin' Up That Rotary Cutter #18
> you have to)
Yes. But sometimes I cheat when I'm not lined up real good and hook up the left lift arm, then the top link so I can adjust the top link to get the right lift arm to line up. This might not work with the bigger implements but sometimes saves time.
   / Hookin' Up That Rotary Cutter #19
The only problem I have hooking up my 5' KK rotary cutter is lining the tractor up good and straight with the middle of the mower. If I do that right, it is a 5 min job at most. The PTO shaft on the KK I got has the spring loaded push-in pin to lock the tractor end to the shaft. It is VERY easy to hook up. I like it a lot better than the sliding collar PTO shaft that is on the Kubota MMM.
Kevin
   / Hookin' Up That Rotary Cutter #20
My Rhino 5 ft cutter has a collar that twists instead of pulling back. I have also removed the PTO shield from the back of the tractor to make hookup faster. Yes, I know this is considered unsafe, but I never go near the PTO shaft if it is turning, and I accept full responsibility for my actions should I be injured because of this.
2013 KENWORTH T880 HYDRO EXC VACUUM TRUCK (A59823)
2013 KENWORTH T880...
2015 Ram 1500 Crew Cab Pickup Truck (A59230)
2015 Ram 1500 Crew...
Deere 35G (A53317)
Deere 35G (A53317)
International 9200 (A56438)
International 9200...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2022 KOMATSU PC360LC-11 EXCAVATOR (A60429)
2022 KOMATSU...
