Hooking up a Shaft to the PTO ?
   / Hooking up a Shaft to the PTO ? #1
Dave5264
Near North Ontario Canada
08 Montana C5264, 2011 McCormick CX100 XS
OK Guys, yet another newbie question.
Went to hook up my 5' bush hog for the first time this weekend and had 2 issues even before i started cutting.
1) I learned why its important to store the Cutter on level ground, what a pain trying to line up the 3 Pont hitch !!
well i got that done and then ..
2) I slide the shaft onto the PTO but Im thinking not far enough...there is a groove in the PTO shaft about 2 " down, and im guessiogn the collar of the mower shaft is supposed to go down that far at least.
there is no spring loaded collar onthe mower shaft but i couldnt get it to slide down more than 1 1/2 inches, just before that groove....what am i doing wrong ? how do i get it to go on farther ?
   / Hooking up a Shaft to the PTO ? #2
The ones w/o the collar usually have a spring loaded pin that you push as you slide on. The pin springs back when released and engages the groove in the shaft.
larry
   / Hooking up a Shaft to the PTO ? #3
Make sure your pto shaft is somewhat clean, a llittle dirt can make the collar hang up.
OK, thanks, dont think mine has a collar and dont recall a Pin...one of the two must be there :eek:
it starts to slide on real smooth then just stops dead
ill have a look see what i can find
thanks alot
   / Hooking up a Shaft to the PTO ? #5
Post a Pic if You Can . Just ran into the Same Problem With a Finish Mower I Bought that was Different from My other shafts . & Thanks to Someone Here They explained it & it was a Piece of Cake .
Mine Either has the Spring Pin. Or The One I Couldn,t Figure out had a Plastic looking Collar That had to be Turned to the Right to Allow it to Slip on Then Back to the left to Lock in Place . Best of luck . Bob
2007 CHEVROLET 3500 DUALLY 4X4 DIESEL TRUCK (A59575)
2007 CHEVROLET...
2019 VOLVO A45G FS OFF ROAD DUMP TRUCK (A60429)
2019 VOLVO A45G FS...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
Ingersoll Rand SD-116DX TF (A53317)
Ingersoll Rand...
2025 Kivel 42in Forks and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel 42in...
2007 MACK GRANITE CV713 DUMP TRUCK (A60430)
2007 MACK GRANITE...
