Hooking up PTO w/ Engine Running
   / Hooking up PTO w/ Engine Running #161
   / Hooking up PTO w/ Engine Running #162
I dont sut the tractor down for an implement change or pto hook up. Most of ours are mecahinical ptos. I have an overrunning coupler on the Yanmar it helps on the pto hook ups over our old 4000 Frods hydraulic pto. I have been scolded for using the lift controle to help hook up the lift from the ground but manufactureres like JohnDeere, And IHC back before my time often had a lift control lever on the back of bigger tractors to aid in hooking up implements.
   / Hooking up PTO w/ Engine Running #163
SPYDERLK,
Hmmm! Elite Member, interests, mechanical design refinement and apparently a certified and licensed mechanical engineer.
I don't ever make comments like the following, but in your case I will make an exception and at the same time I am apologizing to the thread participants.
Spyderlk my be one of the most pleasant people there is on earth and many of his comments my be more in jest than for any other purpose.
If your indicated lack of concern for the safety of yourself and others is for real, I am sure you will let me know in no uncertain terms, but at least I will know where I stand relative to the validity and sincerity of your posts.
In the mean time, until I can figure out where you are going with your style of mocking comments it will be my pleasure to recommend people avoid acquiring your design and mechanical engineering services since your lack of concern relative to safety makes me extremely uncomfortable.
As an Industrial Engineer I worked with some of the very best mechanical engineers out there in the foundry industry, possibly one of the most dangerous industries an engineer will face. The challenges are maximized in just about every way you can imagine, especially in the area of safety.
I truly hope I am way off base here and again I apologize for taking this tone with with one of the forums fellow members, but the more comments by SPYDERLK I read, the more concerned I get about where this thread is headed.
With apologies if needed.
Nick, North West Farmer
   / Hooking up PTO w/ Engine Running #164
SPYDERLK,
Does your post have a specific subject? I cant see what you refer to. :confused:
larry
   / Hooking up PTO w/ Engine Running #165
larry
Dont feel bad, I didn't get the point either. :confused:
Maybe I should go back and re-read the messages again..
Wedge
   / Hooking up PTO w/ Engine Running #166
   / Hooking up PTO w/ Engine Running #167
Probably just oil drag. Should be able to stop it with your fingertips. Otherwise theres an issue with the oil visosity index, or with the drive that should be looked into.
larry
Aaron Z
Oh. Considering the complete post ... or even not, how is that mockery or even unconcern?
larry
   / Hooking up PTO w/ Engine Running #168
SPYDERLK,
Larry,
Last night when I posted in an unkind manner, it was late, I had been finishing a long hard day and for some reason as I was reading your reposted quotes and the comments you were making about them, the statements seemed to be belittling, mocking and know it all in character. I also got a sense that you showed a lack of concern relative to safety from the nature of your remarks.
I made a huge mistake, whenever I develop emotions like those my personal policy is to do nothing at that time, think about it, go over it again and then respond if it still seems appropriate. I shot my mouth off, so to speak, violating my own primary rule, a rule that has kept me from putting my foot in my mouth many times.
When I read over the posts and my responses today, things did not seem the same and I found myself questioning my own statements. I will go over this area of the thread again, see if I can make sense of that area and my comments and then decide what to do. Possibly, the best course of action well be to apologize to you, the forum and anybody else that might have been bothered by my curtness or no additional action at all.
At this point it may be most appropriate for me to communicate with you directly while I determine what action should be taken to most appropriately resolve this in a "yield least harm", manner.
After 69 years it is clear that I still need to work daily at self improvement.
   / Hooking up PTO w/ Engine Running #169
How about it....do you shut down the engine when attaching your rear PTO implements?
Uh.... yes. And I hope your SIL has a good death/dismemberment policy...
   / Hooking up PTO w/ Engine Running #170
when you are in nigeria, would you get my cash too.. apparrently some bank has some money and decided to release it to me since my name is close to the owner's who died and left no heir's.. but I have to split a portion o it withe banks controller.. ;)
I guess they think we are stupid????
soudnguy
When they send that same sorry story, usually in broken English, to 100,000 e-mail addresses, they have pretty good odds of getting a few stupid ones!
   / Hooking up PTO w/ Engine Running #171
And as they always say, God loves stupid people, otherwise why did He create so many of them. (Or was the saying beware of stupid people in large groups) cant remember..."i guess i be stupid" :laughing:
   / Hooking up PTO w/ Engine Running #172
My BX25 is really a compact tractor. Hooking up the PTO was a real pain to hold it up, start the universal on the shaft, turn the PTO shaft to align the spline and fumble with the sleeve or pin locking device (I have both) all while scrunched into the limited space. Solved it; for each PTO shaft took a 4" bail type pipe hanger slid it over the plastic shaft guard, took a piece of all thread and double nut to hanger, bend a hook in the all thread to fit over the top link, set it all line the shaft up with the PTO spline, start the shaft on the spline use a large drift pin and turn the inplement shaft to align the spline, shoveit on, engage the locking device and all mis well. Each one is adjusted for that iplement and ties to the guard after connected. They make a hanger with a latch you could use and take off each time. Thought about it but figured they would either get lost or mixed up anyway. Now a one armed guy could do it. Us old guys have to find the easy ways to get around the stiff joints.
Ron
   / Hooking up PTO w/ Engine Running #173
yep.. I do plenty o stuff that feels way LESS safe than working around my tractor.
like going to the range and seeing NEW people who have just bought their first gun... now that scares me...
soundguy
Bingo! One of the ranges I use has stainless steel counters at the shooting stations and almost every one has a large impact impression from a gun going off and hitting the counter lip between the shooter and the range. Could be from bad handling while shooting (doubtful) or more likely from grabbing the trigger when picking up the handgun and discharging it while still on the counter.
Gives you a warm fuzzy feeling not unlike nausea when you think those people might standing next to you loading their shiny new pistol.
   / Hooking up PTO w/ Engine Running #174
At least it shows a discharge in the right general direction. Maybe they just aimed low.
   / Hooking up PTO w/ Engine Running #175
our range has had the benches with holes in them.. and here's the scarry one. the twin bathroom stals ahve holes shot all the way thru :(
soundguy
   / Hooking up PTO w/ Engine Running #176
soundguy
or you have some pervs in the stalls :laughing:
   / Hooking up PTO w/ Engine Running #177
We often used a public range to qualify, but it was closed to the public when we used it; holes in the bathroom doors, benches, building walls, walkways cratered. I wouldn't go near that thing on a public use day.
   / Hooking up PTO w/ Engine Running #178
just absolutely scarry.. and nobody polices their own brass anymore???
I know some guys that just show up with a bucket and broom and waste pan JUST to pick up brass every time the range goes cold.
soundguy
   / Hooking up PTO w/ Engine Running #180
I have never been to a gun range and after reading a couple of posts on another thread I was thinking it might be nice to check one out sometime so I could try some different handguns. Now you guys have pretty much convinced me it would be safer to just hook up with the pto turning than going to a gun range:laughing:
2000 Thomas Built Saf-T-Liner Transit Passenger Bus (A59230)
2000 Thomas Built...
2020 Ram Promaster City 1500 Cargo Van (A59230)
2020 Ram Promaster...
1990 INTERNATIONAL 3800 DAY CAB DUMP TRUCK (A58214)
1990 INTERNATIONAL...
2016 Ford F-150 Ext. Cab Pickup Truck (A59230)
2016 Ford F-150...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
