How do you build a bridge over a creek for a Tractor
   / How do you build a bridge over a creek for a Tractor #31
I'm in the same boat, but I want it to drive my Jeep over. My stream's about 4-5' wide and shallow. I asked my engineer buddy and he said 4-2X8 per beam would support the Jeep. I'll put 2 in the center to keep the bounce out of the decking when walking or passing with the 4-wheeler. So it'll be 10X14', with three beams, and 2x4 decking.
   / How do you build a bridge over a creek for a Tractor #32
I'm late arriving at this discussion, but sure glad to see it...
I've looked all over the net for bridge info...
thanks
   / How do you build a bridge over a creek for a Tractor #33
Bury an old flat semi trailer in the banks !
   / How do you build a bridge over a creek for a Tractor #34
I've got 3 crossings I need to span / culvert.
Deepest is about 4-5 feet below ground level and about 3-4 feet wide. I took a day off work recently and lined it with the largest field stones I could gather up. It's doing "ok" so far but I wished I'd just put a culvert in.
Next one is about 10' wide and a couple feet deep and very soft - too soft to cross in my jeep most of the time (which just makes it worse) and way too soft to cross with the tractor. I'll prob put a few culverts in it as during a down pour there is LOTS of water run off through it.
Next one is about 3' wide with quicksand (basically) in the bottom. Buried my jeep in it once. Ain't tried to cross that one again lol.
   / How do you build a bridge over a creek for a Tractor #36
Since the cost is close to the same I would use wider deck boards such as 2x8 instead of 2x4.
   / How do you build a bridge over a creek for a Tractor #37
I am looking for one now to use for a ditch crossing. Most of the older ones I use to see have been hauled away when scrap prices went up.
   / How do you build a bridge over a creek for a Tractor #39
...oh, and the Jeep's sold, so this is only for the wheeler so it got scaled down. 6' wide, 12' long.
UNUSED FUTURE FT20 EXCAVATOR (A52706)
UNUSED FUTURE FT20...
2012 NISSAN AWD Rogue (A56859)
2012 NISSAN AWD...
183 (A52705)
183 (A52705)
2014 Ford Fusion Sedan (A56859)
2014 Ford Fusion...
New/Unused CFG Industrial QK16R Mini Excavator (A57453)
New/Unused CFG...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
