How do you dispose of your old hydraulic oil
   / How do you dispose of your old hydraulic oil #11
I store all of my waste oil in a 35 gallon drum, when I prepare my disc and drag for Winter I fill a deck sprayer with the oil and coat my equipment with the oil. Helps preserve what hasn't already rusted away.
If I fill the 35 gallon drum, the rest goes in a 55 gallon drum. So far the 55 gallon drum is less than 1/4 full.
David
   / How do you dispose of your old hydraulic oil #12
In Ontario under the "take it back" program I pay three cents a litre to drop it off at the local garage. Hydraulic oil on the other hand I believe is mineral oil based not petroleum. I have used mineral oil to rust proof car doors. It does not smell bad like petroleum based products. Although you could do a fleet of vehicles with the hydraulic oil from one tractor.
If you want to burn waste oil cleanly I recommend checking out burner plans available online such as these.
Roger Sanders' Waste Oil Heater
   / How do you dispose of your old hydraulic oil #13
County hazardous waste dump. Works well. No fee (other than taxes :D )
Bob
   / How do you dispose of your old hydraulic oil #14
Old hydraulic oil makes great chainsaw bar oil. Some saws, like my Dolmar, pump a lot of oil onto the chain. Regular bar oil turns the saw into a gooey mess. Used hydraulic oil keeps it much cleaner.
Used hydraulic oil doesn't have near the contaminants of used crankcase oil...no combustion byproducts. So it's unlikely to cause pump problems. Of course, 10 gallons of bar/hydraulic oil would probably last me at least 5 years.
Bob
   / How do you dispose of your old hydraulic oil #15
I'm like you Bob, use mine as chainsaw bar oil. I will add about half a can of STP oil treatment when I pour it up in my gallon jug. Makes it a little more sticky.
   / How do you dispose of your old hydraulic oil #16
rswyan said:
Eventually I would like to either find a proper waste burner or make one up myself to use as supplemental heat in the new polebarn.
I figure its a free heat source for the polebarn why not use it.
this is the one im going to build.
   / How do you dispose of your old hydraulic oil #17
Stupid question maybe... but is it fair to say that so-called "Fire Resistant Hydraulic Fluids" will not burn in such a device??? :confused:
Are there other good alternative uses for used "Fire Resistant Hydraulic Fluids"???
Dougster
   / How do you dispose of your old hydraulic oil #18
Great link - thanks for posting it !
   / How do you dispose of your old hydraulic oil #19
I use it to start my burn piles. Just pour it out over the logs and let them burn.
Eddie
Randy I currently have 10 gallons of used but otherwise clean hydraulic oil sitting here if you want it. It would be free fuel if you're thinking about a waste oil furnace. Otherwise it will end up in a log splitter.
10 Snow Plow W/ Bracket (A47477)
10 Snow Plow W/...
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2007 OVERLAND  TANK TRAILER (A53843)
2007 OVERLAND...
2012 PETERBILT 388 DAYCAB (A55745)
2012 PETERBILT 388...
CATERPILLAR 420E BACKHOE (A52707)
CATERPILLAR 420E...
