How do you dispose of your old hydraulic oil
   / How do you dispose of your old hydraulic oil #31
SPYDERLK said:
Originally Posted by FritzII
I think I read on this site that someone's wife poured used hydraulic fluid into the fuel tank because her husband had put it in diesel fuel cans temporarily. The consensus was that this was not a problem ?
How about filtering it and running it in 10%/90% hydraulic/diesel fuel mix ?
This occured to me as well. So far I haven't tried it. Anybody had experience?
Larry
I had a gallon of fresh UTF left over, so added half a gallon to 2 or 3 gallons of diesel in the tank. It cranked slightly longer before starting then ran fine. It had a faint smell of overheated transmission. No problems. I am assuming that hydraulic and UTF burn about the same.
   / How do you dispose of your old hydraulic oil #32
DieselPower said:
Whenever I have a burn pile I just make sure I call county control before I light it. That way if someone calls the fire department they know it's a controled burn that is being monitored.
I do the same thing. My ground is sooooooo soft that the fire engines (tired for asphalt) get stuck. The City apprecaites the call. I even give them my cell #.
Bob
   / How do you dispose of your old hydraulic oil #33
PineRidge said:
Eddie can't get away with that around here. I've had some pretty big fires when we were clearing our land but the smoke would be a problem for sure.
I have to get a burn permit and the pile cannot exceed 3'x3'x3'.
I just keep my FEL loader ready and keep stoking the fire as it shrinks below 9 cu ft.
Bob
   / How do you dispose of your old hydraulic oil #34
I have a very large stump that has a few crevaces starting to rot in the top of it... I pour the oil down in there, and I still haven't burned very much of the stump in four years!
   / How do you dispose of your old hydraulic oil #35
Dispose of ?? I thought that hyd. oil was a part of the cycle of nature. It slowly dissapears from the hoe, and in due time it will pe pumped up from some oil well, in my case, the north sea.
www.statoil.com
   / How do you dispose of your old hydraulic oil #36
Local Kubota dealer takes mine.
   / How do you dispose of your old hydraulic oil #37
EddieWalker said:
I use it to start my burn piles. Just pour it out over the logs and let them burn.
Eddie
How flammable is this stuff?
Bob
   / How do you dispose of your old hydraulic oil #38
I usually use mine to encourage my burn piles. I sometimes take it to work, if I don't want to store it, where we have an oil disposal tank.
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
2013 Audi A6 AWD Sedan (A53424)
2013 Audi A6 AWD...
NorthStar VR-344 (A53314)
NorthStar VR-344...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
New/Unused 72in Quick Attach Brush Cutter (A54865)
New/Unused 72in...
Galvanized Steel Fence 10ft x 7ft (A55758)
Galvanized Steel...
