How Do You Keep A Draw Bar From Spinning?
   / How Do You Keep A Draw Bar From Spinning? #1
Utopia Texas
Platinum Member
Brookshire & Cat Spring,Texas
Kubota B2650 / Kubota L6060 / Kubota ZD2300
I have one of the bars that attaches to the lower right and left hydraulic three point lifts on my tractor with a trailer hitch ball bolted on to move trailers around here on the property. As you know the weight of the ball makes the bar spin around where the ball points straight down. How does one keep the bar from rotating where the trailer hitch ball stays pointing up? Thanks...
   / How Do You Keep A Draw Bar From Spinning? #2
There were slotted brackets made that went over the ends of the drawbar and then clasped the 3 point arms if I recall correctly.
Edit
Found it
Massey Ferguson Universal Drawbar Lock For all Massey Ferguson (DBL2)
   / How Do You Keep A Draw Bar From Spinning? #3
I think you have a couple of options. There is a pair of clips available that attaches one to each draft link and the draw bar itself so that draw bar can't rotate. Not sure who offers them. There is a bolt on piece available that bolts to the middle of your draw bar on one end, and the other end of it will attach to your top link, which keeps everything locked in place so the bar can't rotate.
Here's a sample of the latter piece that I mentioned:
OMNI Standard Duty Draw Bar Hitch - OMNI Mfg LLC
Then again, most people just make their own trailer mover (3pt handi-hitch), like I did.
   / How Do You Keep A Draw Bar From Spinning? #4
tractor supply sells draw bar locks http://media.tractorsupply.com/is/image/TractorSupplyCompany/1000786?$prod_det$
I now use a " heavy hitch " much better, more useful.
   / How Do You Keep A Draw Bar From Spinning? #5
Here it is
   / How Do You Keep A Draw Bar From Spinning? #6
Tractor Supply Co. - Enjoy searching:Drawbar Lock
Drawbar Lock-Category 1 | Agri Supply #63963
Thanks for all the replies. A lot more options than I imagined!
   / How Do You Keep A Draw Bar From Spinning? #8
Since you already have the drawbar, buy a receiver tube and you can make this.
   / How Do You Keep A Draw Bar From Spinning? #10
Xfaxman ... (you may be already aware, a newbi not likely) Be veeeerrry careful of pulling with anything attached at the level of the top link. Unless you want a rearing tractor! ROPS may protect you , but you'll spill your beer!
Always pull with the attachment point below the rear axel.
Toyota SR1-BET35 3,500LB Stand-On Electric Forklift (A59228)
Toyota SR1-BET35...
Mini John Deere Truck (A55853)
Mini John Deere...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
PowerBoss Admiral Plus 38C Ride-On Floor Scrubber/Sweeper (A59228)
PowerBoss Admiral...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56438)
2002 Chevrolet...
