Hey gents, the sicklebarmower is a WheelHorse OEM unit made by Haban back in the 70's. My 856 is rated for the 42" sicklebar and I was told the 50" would be too big but I took a chance, pieced together a unit from another fellow and my 8hp 856 has no touble at all working it.
Inorder to bolt it up, I have to remove the belly mower's mid mount quick attach (pic #1)
The sicklebar assembly mounts in the front where the mid mount quick attach mounted and it "slides" on a bar that mounts just in front of the tranny. It slides to adjust the drive belt (Pic #2)
The same foot PTO that is used to work the belly mower is also used to engage the engine to primary sicklebarmower pulley. At 1st I'd just move the PTO but I later purchased another foot PTO on ebay so I don't have to swap it between mounts. On the same shaft inside of the front mounts is the 2nd'ary drive pulley which drives the 2nd'ary belt, makes a sharp 90 degree via two idler pulleys then loops around the sicklebarmower's gearbox pulley. (visable in pic#4)
The sicklebarmower will cut at any angle, even in the vertical transport position. It is not a quick attach implement but it's not that hard to R&R as a single assembly. I generally take it off for winter storage as I use the 856 with a snowblade when the rare snows hits us. Useing a dollie makes it about a 1/2 hr job and I can then roll it out of the way for stowage.
I've had it for 3 mowing seasons now and it has earned its keep 10 fold!
It's made keeping that bank mowed and also keeping the weeds down around my small pond a nice easy sitt'n on my can mow
They both used to take hours to do with a weed eater and now I knock 'em both out in about 20 minutes, whch is hardly enough seat time to suit me
Any other questons or pics just let me know.
