How do you repair a damaged Kubota cab top ?
   / How do you repair a damaged Kubota cab top ? #31
   / How do you repair a damaged Kubota cab top ? #32
Murph, with all the trees, we had to add the brush guards or just keep fixing lights and cracked roofs, so far it's worked out pretty well and hope to add them to our M8540 this winter.
   / How do you repair a damaged Kubota cab top ? #33
That is the only way I would take a Cab Tractor into the woods..Nice Job your brother did.
   / How do you repair a damaged Kubota cab top ? #34
Thanks, I sure am lucky to have someone willing to do that kind of work. When he was fifteen, I had him help me change transmissions on my 54 Ford car and he took off from there, his son is the same way. He can do mechanical, welding, carpentry, drywall, flooring, electrical, plumbing...
   / How do you repair a damaged Kubota cab top ? #35
you make have these posted somewhere else, but could you post more pictures of the tree deflection cage you built?
   / How do you repair a damaged Kubota cab top ? #36
I bet he does them all perfectly too as he did with that cab repair. That being said, I bet he feels pretty lucky to have a brother like you too. I'd have no issues letting him work on my stuff. Good job!
Keep well buddy
   / How do you repair a damaged Kubota cab top ? #37
Don't know if you were addressing me, but if you were: http://www.tractorbynet.com/forums/owning-operating/302353-brush-guard-cab-tractor.html?highlight=
Keep well buddy
Thanks Paul; but kinda one sided lately, but I help him out when I can, we're really close.
Best wishes
   / How do you repair a damaged Kubota cab top ? #38
If looks aren't all that important: I repaired several cracks in a canopy a friend gave me - I first sanded the canopy next to the cracks, and drilled holes along both sides of the cracks. I then secured the crack with heavy zip ties strung though the holes - like stitches. I then mixed up a big batch of 5 minute epoxy and flowed it over the crack and zip ties, then repeated on the other side. Both sides get bonded together through the drilled holes. After I was all done, I blasted it with spray paint. Worked great and looks good enough to be on top of a roof that I never see.
   / How do you repair a damaged Kubota cab top ? #39
yes sir that what i was looking for shots of the mounting points.
thats enough info for me to be dangerous. :)
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A53472)
2023 NEW HOLLAND...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
JOHN DEERE WHEEL LOADER 71" FORKS (A51246)
JOHN DEERE WHEEL...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
2017 E-Z Beever M12R Towable Brush Chipper (A50322)
2017 E-Z Beever...
