How long does it take to put front snowblower on a BX?
   / How long does it take to put front snowblower on a BX? #11
On my b2620 it takes me 15 minutes max to drop the fel ,install the sub frame,install drive shaft, and then install blower and the front shaft.
   / How long does it take to put front snowblower on a BX? #12
Much easier than putting on the mower. Takes me about 15 minutes all told, and I'm old and fat.
   / How long does it take to put front snowblower on a BX? #13
For, me, on my BX2670, less time for the blower than the mower, but longer than either was on my Wheel Horses.......
As some mentioned, a lot might have to do with which model of tractor, which model of blower, and whether the friends brought beer or not.
Personally, the front mount snow blower is the ONLY way to go. No matter how deep or far through the drift is, you just keep going, and never have to go 10 times farther to make sure there is room for next time like you have to do with a front blade. I wait for the storm to end, don't go out in the middle of a blizzard because I'm afraid of not being able to push through. No backing up like a front loader that can't be pushed through because the snow is too deep. With age and physical limitations, I don't have to twist around in the seat, which I can't do anyway, as a rear mount snowblower requires.
Now, if you like spending 4 times as long in the cold, if you like putting 4 times the hours on your equipment, if you like being twisted around in the seat, well, you might like one of the other methods better.
   / How long does it take to put front snowblower on a BX? #14
Here is what I do with my BX2360:
Remove 2 pins on my LA243 FEL (about 2min) adjust the control lever to release the FEL(about10 sec). Disconnect the 4 quick connect hydraulic hoses (1min)
Back the tractor away from the FEL.
Install the subframe that the front blower/blade mount to(10min)
Put on the mid mount PTO shaft(10min)
Drive the tractor to where the blower is sitting(B2750 48"blower)
Mount the blower(5min)
The trickiest part is lining up the square drive from the blower to the drive on the subframe but all told this takes about 30 min at the most to switch from the FEL to the blower. The first time I did this it took quite a bit longer, but I have gotten better and it now takes less time.
   / How long does it take to put front snowblower on a BX? #15
Spoke to a man yesterday and he said he sold his front mount snowblower because it takes 2-3 hours and two people to put it on and off, is this true?
Hi, first NO it will not take that time, let me explain,
First you have to fit the front quick hitch subframe and the pto driveline kit, this will take you 15min.
After that you will fit the blower in 5 min. As you already have the front quick hitch subframe on you can easy fit a snowblade and then back with the blower in 5 min
Im still very impressed of the front mounted snowblower, and its very fun to drive :thumbsup:
good luck
/Sam
   / How long does it take to put front snowblower on a BX? #17
It may be different for other models of tractor, but the front mount blower for a B2650 was $6500+ and a rear was ~$3000. That's a deciding factor for me. Not sure about BX models, but I know I could do a lot with the over 50% savings in cost!
2015 WESTERN STAR 4900 SF (A45333)
2015 WESTERN STAR...
4'x8' Quick Attach Safety Basket (A44502)
4'x8' Quick Attach...
2006 Ford E-350XL (A44501)
2006 Ford E-350XL...
2016 Ford F-150 Pickup Truck (A44572)
2016 Ford F-150...
2016 Ford F-250 Knapheide Service Truck (A44571)
2016 Ford F-250...
2016 Ford F-250 Pickup Truck (A44572)
2016 Ford F-250...
