How many amps should a starter draw? JD 155c mower
   / How many amps should a starter draw? JD 155c mower #1
davesl708
Elite Member
Shawnee, KS, USA
Kubota BX2200D,
Hi Folks,
I am working on my neighbors JD 155c. It has a short that is blowing the 20 amp fuse.
I can track that down.
The question I have is when bench testing the starter it draws 24 amps. Under load it draws 103 amps.
This seems high to me. Does it sound like the starter is getting bad too?
   / How many amps should a starter draw? JD 155c mower #2
Book says max no load is 35 amps and max load is 180 amps. Sounds like your numbers are good. Does it crank over fast enough?
Thanks, I don't have any manuals for it.
Seems to. I cleaned and lubed the bushings. That helped lower the amps.
   / How many amps should a starter draw? JD 155c mower #4
If you want to the starter motor to make 1Kw to crank a motor. The current will have to be 1000W / 10V / 66% efficiency = 150amps.
UNUSED FUTURE HYD AUGER (A52706)
UNUSED FUTURE HYD...
2013 Dodge Durango (A53317)
2013 Dodge Durango...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A58214)
2008 TEXAS BRAGG...
SKID STEER ATTACHMENT AUGER (A58214)
SKID STEER...
