how many units of diesel/hour for CUT's
   / how many units of diesel/hour for CUT's #11
I've been averaging 10 hrs per 5 gallons in my 25hp Kioti CK25. That is bush hogging, pushing over and moving trees into piles and digging and moving dirt/sand with the FEL.
   / how many units of diesel/hour for CUT's #12
On average about .75 per hour. Does depend on what I'm doing. Mowing and light FEL I run about the .75 mark. Heavy FEL or box blading about a little over 1gal/hr. I'll be doing some plowing soon so I'll get an idea then.
   / how many units of diesel/hour for CUT's #13
I average around 3.5 to 5 gals. per 8-9 hr day tilling, bushhogging, or backhoeing, tilling being the hardest use. Gary
   / how many units of diesel/hour for CUT's #14
I use 1.1 gal per hr. in my JD4700 (48 engine hp) at pto speed 2700rpm mowing with the bushog.
David
   / how many units of diesel/hour for CUT's #15
JD 3320 (32.5 hp)
Just put on 14.4 hrs pushing/moving lots snow at 8,500' @ 1400-1500 rpm. Filled up with 6.6 gals.
Doing lots of backhoe'ng at 1000 rpm and get closer to 3 hrs per gallon. :D
   / how many units of diesel/hour for CUT's #16
My 18.5 hp 4010 has averaged 0.46 gallons/hr over about 350 hours. I record the hours every time I finish a 5 gallon container.
My 12 hp carbureted Gravely tractor ran about the same fuel use, but my numbers weren't that accurate on it.
My 1983 diesel Benz has averaged 29 mpg over 210k miles. Just replaced the timing chain. Mileage and performance seem to have both improved. The stretched chain was retarding the valve timing. It's about 3200 #.
My 1996 Tacoma 4 cyl, 5 spd, 2wd averaged 27.4 mpg over 90k miles I had it. It was 2940 #.
The 1997 VW Cabrio averages 31-34 mpg. it's 2700 #.
Carbureted vehicles (cars and pickups) used to average 30 mpg-ton while diesels averaged 45 mpg-ton. Fuel injected vehicles now seem to run about 27 mpg - 1.5 ton with diesels doing about 30% better.
Ralph
   / how many units of diesel/hour for CUT's #17
My Mahindra 3525 (35 engine hp/ 27 pto hp) averages about .75 gal/hr while running my finish mower, and about 1.2 gal/hr running the 6' tiller.
Well thanks for the data points guys, except for lbrown.
Here's a .csv file using - for delimiter and " to wrap text, and make it slightly readable.
"make"-"model"-"hp"-"gal/hr"-
"mahindra"-"?"-26-"<1"-"george2615"
"kubota"-"?"--"10gal/month"-"lbrown"
"kubota"-"?"-21-0.5-"BruceWard"
"kubota"-"bx2350"-23-0.5-"smallfarmer"
"kubota"-"b7500"-21-0.6-"rusty"
"kubota"-"bx24"-23-0.33-"oldertoday"
"kioti"-"ck25"-25-0.5-"sunnyjim"
"jd"-5103-45-0.75-"rwolf"
"kioti"-"ck20"-23-0.5-"garydc"
"jd"-3320-32.5-0.47-"zr2blz"
"jd"-4010-18.5-0.46-"ralphva"
"mahindra"-3525-35-0.75-"xlr82v2"
It looks like the 20 to 24 hp burn about .5 gal per hour. Except for Lbrown who gets about a month on 10 gallons.
   / how many units of diesel/hour for CUT's #20
Let me kick my 2 pennies worth.
Tractor is a New Holland 35A. 3 cylinder diesel engine. Sychronized Shuttle Shift.
When used for bush hogging and pushing out large multiflora rose bushes and small scrub trees with the FEL, about .75 to .85 gallons per hour. When using it for hauling brush and lighter loader duties, it does better, close to .50 to .60 gallons per hour.
2006 Volkswagen Jetta Sedan (A55758)
2006 Volkswagen...
2016 Ford Taurus Sedan (A55853)
2016 Ford Taurus...
LINCOLN ELECTRIC RANGER 225 GAS WELDER/GENERATOR (A54757)
LINCOLN ELECTRIC...
2004 Sterling Acterra Cab and Chassis S/A Truck (A55852)
2004 Sterling...
2018 John Deere 1025R Tractor - 257 Hours (A55314)
2018 John Deere...
406 (A52706)
406 (A52706)
