How much can a 40hp tractor tow??
   / How much can a 40hp tractor tow?? #41
Back it down the slope, bucket loaded with sand. If you begin to lose traction while braking then drop the bucket. Never let the tractor get even the slightest bit perpendicular to the slope.
   / How much can a 40hp tractor tow?? #42
I don't think you will have any problems with sufficient power to pull. The problem will lie with sufficient weight & traction. Does the tractor have sufficient weight to provide the traction needed. You don't want to get into a situation where the "load" is requiring more traction than the tractor can provide.
Your tractor lists at 4130 to 4566 pounds without FEL or added weight. I would hook it up and try it on level ground and see how it acts.
:thumbsup: Get as much ballast on the rear tires as possible. Load tires and axle weights if possible.
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
CATERPILLAR 255 SKID STEER (A52705)
CATERPILLAR 255...
23013 (A55787)
23013 (A55787)
John Deere 73 Inch Materials Bucket - Needs Carrier (A55218)
John Deere 73 Inch...
2022 Ford Escape S AWD SUV (A55853)
2022 Ford Escape S...
New/Unused Easy Clean Hot Water Pressure Washer (A54865)
New/Unused Easy...
