How often should you change the spark plug on a push mower?
   / How often should you change the spark plug on a push mower? #11
I have had many push mowers over the years, have 2 right now. As someone else said only change if needed. the 2 I've got now have been running atleast 8-10yrs on the their original plugs.
Is anyone aware of a commercially available, inexpensive device for cleaning plugs? There has to be a better way than pocket knife, sand paper and wire brush that I use :confused:
Rekees4300 I use a wire wheel or wire bursh, it makes them purty and shiney.
   / How often should you change the spark plug on a push mower? #12
What do you call inexpensive? $13 to $30 do? Just go to google.com and enter "spark plug cleaner" and you'll see that Harbor Freight, Nothern Tool, and lots of others sell them. They've been around for a lot of years, but for me personally, it's cheaper to just buy a new plug when I need one.
   / How often should you change the spark plug on a push mower? #13
Unleaded gas has made spark plug changes rarely needed. I'd change it only if having problems -- even then it will likely not be the plug. I have several mowers, weedeaters (Jonsered), and blowers (echo) that are still on original plugs after 8+ years....
   / How often should you change the spark plug on a push mower? #14
I change the plug every year. Set gap at .030 on the new plug. Reason being is less carbon build up on valves. That is only my preference. Air filter also every year, oil change at start of season and depending on use half way through season, 30 wheight oil.
   / How often should you change the spark plug on a push mower? #15
As needed on mine, I had to replace em in the string trimmer & push mower this year, unknown years on the string trimmer got used and 12 years on the push mower.
   / How often should you change the spark plug on a push mower? #16
I change my plugs 2-3 years on average, pull and clean every year.
TOOTHED BUCKET ATTACHMENT FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET...
2017 FORD TRANSIT 250 CARGO VAN (A59575)
2017 FORD TRANSIT...
2001 WELLS CARGO 8' X 32' TOY HAULER DBL AXLE TRL (A57192)
2001 WELLS CARGO...
2003 Big Tex 10PI...
CABINET OF HOSE ENDS (A58214)
CABINET OF HOSE...
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58214)
2013 ORTEQ ENERGY...
