how should I flush hydraulic fluid?
   / how should I flush hydraulic fluid? #11
What fittings do you use to do this? Is blowing seals a problem?
blown seal?
ag hyds usually operate around 2500 psi
Most air compressors operate between 120 and 150 psi.
Does your air compressor put out more than 2500 psi?
If so.. I'm impressed! :)
blown seal?
Well my assumption is that the packing is designed for viscous hydraulic fluid not nitrogen gas. So a PSI is not necessarily a PSI.
   / how should I flush hydraulic fluid? #13
and??? what's the possible worst that will happen.. a temp air leak?
remember.. again.. the seals are designed to contain 2500 psi of essentially uncompressible fluid...
150 psi of quite compressable gas is laughable.... hard to even make a comparison really.
I have only flushed implements (hoes and FELs) with external mechanical force
applied to them to articulate all the cylinders and collect the fluid via the tank
return hose. Doing this dynamically with the tractor hyd pump running would
work, but I have not tried it. I don't want to lose too much clean expensive fluid.
Ya, it just occurred to me that the hoe valve bank is probably open center so I'd be loosing 12+ GPM of good fluid from the time I start the engine (and not just when I actuated a valve)!
Is my thinking correct?
If so, I'm back to manually cycling the pistons or using air.
I wonder what the large dealers do?
   / how should I flush hydraulic fluid? #15
Not a danm thing, I will bet.
You will lose some fluid if you run the tractor. Even at idle, prob 3 GPM thru the open-center
valve. Too much? That's your call.
   / how should I flush hydraulic fluid? #16
The suggestion I offered was intended for use with an open center, power beyond type system, using a third, sump return line. In which case no oil flows through this line unless a valve is in use. If your hoe has only two hoses connected to tractor hydraulics, that's a different matter. As for the listed methods for removing existing fluids from cylinders and lines, I'm sure any/all of them would be effective. I made my comments based on your first post, in which you asked about a simpler method.
Harry, I really appreciate your help and did not mean to ignore it. On my Case 680s there was 2 return lines. I'll have to go out and look at the Woods hoe this weekend when I'm home while it's light. There are only two lines connected to the tractor but the return lines may Y together upstream.
I does make sence that there should be a return line from the valve assembly when all the valves are closed and another return line from the cylinders. There would only be fluid returning from this second line when one of the valves is opened.
Am I thinking about this correctly?
What are the proper names for these lines? Sump return and.. ?
Will it be obvious which line is which or can you give me some tip to identify which is which?
Again thanks!
   / how should I flush hydraulic fluid? #18
Where I have been working, we use compressed air to remove oil from cylinders, before, and after, rebuilding them. As well as, compressed air to initially test them.
A blow gun with a rubber tip, and a rag, usually works fine, on the inlet, or outlet threads.
Yes, you would have to break a lot of lines loose. But, everything is pipe thread once you remove the couplers, and hoses, just like air fittings, so it's not hard to cobble up something that you can couple up to.
Low pressure is recommended. This is due to the fact that it will cause rapid piston movement, and lots of flying oil.
Ok cool. Rubber tip seems simple. What's the rag for? What do you consider low pressure?
   / how should I flush hydraulic fluid? #20
Woods hoes and all other CUT hoes I have seen have only 2 lines, IN, and OUT. AUX valves
sometimes have a third line call Power-Beyond. Industrial hoes usually have more lines cuz
they use 2 pumps (swing, and boom/dipper/bkt). Except the B21 hoe, it has only 2.
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
2014 Magnum 7696BLA Light Tower (A59213)
2014 Magnum...
2017 Bobcat E55 (A60462)
2017 Bobcat E55...
LAND PRIDE RCR1260 5' ROTARY MOWER (A59823)
LAND PRIDE RCR1260...
2022 Kubota LX2610SUHSD Compact Utility Tractor (A55315)
2022 Kubota...
SALTYS MANFUFACTURING 500BBL FRAC TANK (A58214)
SALTYS...
