How to chain up the tractor?
   / How to chain up the tractor? #11
Highbeam,
I originally used the stake pockets but like you say as the chain binders were tightened the chain could not slide very well through the pocket. Mainly as it tightened the part of the chain that moved was the part going around the tractor frame which is round. I have since welded on D-rings which allow the chain to move as it is tightened. I have not added D-rings to my gooseneck yet and still use the pockets but I still go through the pocket and hook one end of the chain back on itself then hook the ratchet binder to the other end of the chain and to a link above the hook by the stake pocket.
By the way, I haven't been following the thread on your loader stress cracks. How you making out with that?
   / How to chain up the tractor? #12
On the cracks, I am still waiting for the release of the official Kioti repair/upgrade to my loader. I was given a three month timeframe. In the meantime I am using the loader like loaders should be used. Thanks for asking.
   / How to chain up the tractor? #13
gordon21 said:
Use the axles. Do NOT use attach points such as the 3PT arms, implements attached to the tractor , loader arms, steps, weight brackets, etc
Use four chains and four chain ratchet binders with grade 70 chain. The difference between cheap chain and grade 70 is probably less than $20 for a typical tractor & trailer combo hauling a compact tractor.
Always loop your chain down through the stake pocket and then back up to hang vertically on the stake pocket. This way, if the chain ever loosened a little bit, gravity will keep it in place and your load safe. If not, you run the chance of the chain completely coming loose.
Read specifics in Fed. regs, and MOST state regs. They require SEPERATE chains/tie-downs on implemements, loaders, back hoes, even if they are PERMANENTLY attached to a tractor.
Chains on the tractor must pull towards 4 corners, but UNLESS tractor(and attached implements/loader/back hoe) is over 10,000lbs, 4 SEPERATE chains aren't required. 2 will do.(to meet legal requirements. SAFTEY suggest's 4 is better)
   / How to chain up the tractor? #14
Like FWJ said under 10,000 4 are SUGGESTED.. however.. after reading the thread about nasty wrecks..it reminded me someone can take out one binder and leave 75% of my tie down points... with only two your are down 50% even if only one corner is hit... I also put a half-hitch type thing in when looping up to the trailer railing to lock the chain down....
   / How to chain up the tractor? #15
We used 4 vehical straps (The thick 2.5" ones) and 4 axle straps.
1 strap at each corner around the axles.
   / How to chain up the tractor? #16
Depends on where you are. Always check your state regs. Some time ago I contacted CHP; here in Calif they want to see four chain/binder or straps, plus additional on the back hoe, loader, ect.
Better to talk to law enforcement before, not after, you get a ticket :eek:
   / How to chain up the tractor? #17
On my NH 1920 with loader & backhoe I attatch a chain and load binder to the front weight bracket on each side (tried using only 1 binder and the other side was kept under tension) and then to stake pockets. In the rear there is a clevis mounted through the drawbar and a single chain and load binder goes from one side to another.
I leave the backhoe in the up position with the boom lock pin in (prevents side to side movement) and the other lock to keep the boom from settling down. Bill C
   / How to chain up the tractor? #18
I will insist on FOUR seperate chains for the corners. If you use one chain at each end and tie to each corner, what happens if the rear chain fails or loosen?? You will suddenly find yourself with one chain holding the front axle from going BACKWARDS. That would be no help in a sudden braking situation. If you buy a 20' chain and use it around the rear axle and tie to both corners, you can double your safety factor at no cost by cutting it in half and tying TWO 10' chains at two seperate corners.
Others have pointed out my error in "suggesting" another chain specifically for the backhoe. You should definitely use the fifth chain if you have an attched backhoe.
   / How to chain up the tractor? #19
Four chains, binders, plus an extra set to go across the loader and/or hoe. What, $150-$200 or so?
My Kubota B8200 is 20 years old, but still a $8000 or so tractor. My trailer is a couple years old; cost $1600 out the door. My truck is 5 years old; cost $32k back when but is still a $20k replacement now. My wife, kid, and not to forget the people in the community around me are invaluable.
What's $150 extra in chain and binders? Based on $29600 of replacemnt value for my basic equipment, $200 worth of chain and binder is 0.006%.
Y'all aint making an error with some extra chain.
   / How to chain up the tractor? #20
I haul a Branson 3510 w/ BH and FEL on a 16' flat bed. My dad works for Texas DOT so in the beginning we used their requirements - one chain/binder per corner and one on each implement. Since Dad is not always around I do admit to cutting corners somewhat.
I usually pull the tractor on nose first - balances better that way - and drop the FEL to the deck and put it against the forward rail. I put one chain side to side at the front over the frame extension/push bar. This chain leads forward slightly holding the machine on the trailer and pushing the bucket against the forward rail. I do not chain the FEL bucket down. Back aft I run two chains from the main axle/ROPS connection lug on each side (chain is wrapped around the axle) to each corner of the trailer, with a binder on each. In this configuration the BH hangs off the back of the trailer if left centered. I swing the hoe to the driver's side - so I can see it while towing - and bottom it out and place it against the side rail. I then use the slack loop from the left side after chain and wrap the hoe bucket and attach it to the rail upright - this keeps the BH from swinging and keeps the bucket on the deck. I don't have the luxury of pinning the BH as the pins are a casualty of my Dad's garage - not that I could and still keep the BH on the deck.
It goes without saying that the tractor e-brake is set and the machine is left in gear.
I tow only locally and on familiar back roads. If I have to get on the interstate I put two chains on the front axle, both wrapped around the axle. The chains cross under the tractor to get a better lead, i.e. the chain around the left side axle goes to the right side of the trailer.
2014 Chevrolet Silverado 1500 Pickup Truck (A55973)
2014 Chevrolet...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A56438)
2017 Yale GLC050VX...
John Deere 6110M (A53317)
John Deere 6110M...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
