How to convert cat 0 to cat I
   / How to convert cat 0 to cat I #1
JeffinNE
just outside Lincoln, NE
JD 2320 & JD LT190 mower
Found a nice, newer JD cat 0 single bottom plow on craigslist. How hard (and expensive) to convert to cat I to pull behind a JD 2320?
I have no welding equipment nor welding skills!
   / How to convert cat 0 to cat I #2
I hope you didn't buy it. Cat 1 tractors usually do a pretty good job of destroying Cat 0 implements
//greg//
   / How to convert cat 0 to cat I #3
I tried to do that with my 2305 and it didn't work. The lift arms would not move in close enough to connect to the plow. I believe the adjustment for the lift arms is the same as on your 2320. And even if I could have "made" it fit, the top link was to wide to fit onto the plow. I ended up making my own mast for the plow.
   / How to convert cat 0 to cat I #4
i dont know about cat 0. but cat 1 and cat 2 3 point attachments well cat 2 tractor doesnt have problems using cat 1 pins.someone i know all of their implements are cat 1 while their tractor is cat 2 and they never had any difficulty using them . and you can just buy big pins if need be . but again for the cat 0 the probably to small for the arms to reach
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2014 Ford F-150...
AGRI X 6' ROTARY MOWER (A57192)
AGRI X 6' ROTARY...
2014 BMW X3 XDrive28i AWD SUV (A55853)
2014 BMW X3...
1989 Hyster H40-XL-MIL 4,000lb Diesel Forklift (A55851)
1989 Hyster...
Honda EM3500SX Portable Gasoline Generator (A55851)
Honda EM3500SX...
2024 JOHN DEERE 1025R LOT NUMBER 106 (A53084)
2024 JOHN DEERE...
