How to convert cat 0 to cat I
   / How to convert cat 0 to cat I #1
JeffinNE
just outside Lincoln, NE
JD 2320 & JD LT190 mower
Found a nice, newer JD cat 0 single bottom plow on craigslist. How hard (and expensive) to convert to cat I to pull behind a JD 2320?
I have no welding equipment nor welding skills!
   / How to convert cat 0 to cat I #2
I hope you didn't buy it. Cat 1 tractors usually do a pretty good job of destroying Cat 0 implements
//greg//
   / How to convert cat 0 to cat I #3
I tried to do that with my 2305 and it didn't work. The lift arms would not move in close enough to connect to the plow. I believe the adjustment for the lift arms is the same as on your 2320. And even if I could have "made" it fit, the top link was to wide to fit onto the plow. I ended up making my own mast for the plow.
   / How to convert cat 0 to cat I #4
i dont know about cat 0. but cat 1 and cat 2 3 point attachments well cat 2 tractor doesnt have problems using cat 1 pins.someone i know all of their implements are cat 1 while their tractor is cat 2 and they never had any difficulty using them . and you can just buy big pins if need be . but again for the cat 0 the probably to small for the arms to reach
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2012 Chevrolet Colorado Ext. Cab Pickup Truck (A55852)
2012 Chevrolet...
2006 BMW 325i Sedan (A55853)
2006 BMW 325i...
2019 RBR Venturi 380 (A55301)
2019 RBR Venturi...
2016 Mitsubishi Fuso FEC52S Cab and Chassis Truck (A55852)
2016 Mitsubishi...
