How to convert cat 0 to cat I
   / How to convert cat 0 to cat I #1
JeffinNE
just outside Lincoln, NE
JD 2320 & JD LT190 mower
Found a nice, newer JD cat 0 single bottom plow on craigslist. How hard (and expensive) to convert to cat I to pull behind a JD 2320?
I have no welding equipment nor welding skills!
   / How to convert cat 0 to cat I #2
I hope you didn't buy it. Cat 1 tractors usually do a pretty good job of destroying Cat 0 implements
//greg//
   / How to convert cat 0 to cat I #3
I tried to do that with my 2305 and it didn't work. The lift arms would not move in close enough to connect to the plow. I believe the adjustment for the lift arms is the same as on your 2320. And even if I could have "made" it fit, the top link was to wide to fit onto the plow. I ended up making my own mast for the plow.
   / How to convert cat 0 to cat I #4
i dont know about cat 0. but cat 1 and cat 2 3 point attachments well cat 2 tractor doesnt have problems using cat 1 pins.someone i know all of their implements are cat 1 while their tractor is cat 2 and they never had any difficulty using them . and you can just buy big pins if need be . but again for the cat 0 the probably to small for the arms to reach
RING 2 STARTS HERE @ 9:15 AM (A57192)
RING 2 STARTS HERE...
2019 CATERPILLAR 740GC OFF ROAD DUMP TRUCK (A52707)
2019 CATERPILLAR...
2023 Kubota KX057-5 Compact Excavator with Angle Blade (A55315)
2023 Kubota...
16ft T/A Flatbed Trailer (A53424)
16ft T/A Flatbed...
2024 Hydraulic Trencher Skid Steer Attachment (A55851)
2024 Hydraulic...
UNUSED FUTURE...
