How to Determine PTO RPM's ?
   / How to Determine PTO RPM's ? #1
TimP
Platinum Member
Kingsville, MD
B3000HSDCC
How to Determine PTO RPM\'s ?
Hello All !
I have a B2150 and an Allied/Buhler snowthrower. It's designed to run at 540 RPM's. But How do I know when I hit that RPM speed on the rear PTO ?
What RPM's should the tractor engine be turning to hit this PTO speed ?
Thanks. Tim
   / How to Determine PTO RPM's ? #2
Re: How to Determine PTO RPM\'s ?
I am not fimilar with a B2150.
Does tractor have a Tachometer? If it does, there should be a line around 2000 to 2800 rpms that indicates PTO 540 RPM's.
   / How to Determine PTO RPM's ? #3
Yes it has a mark on the tachometer for 540 Ron. /forums/images/graemlins/grin.gif
Hmmmm....
Well don't I feel stupid !
When I get home today, I'll have to take a closer look.
Never noticed, but then again, never really looked !
Thanks !
Tim
   / How to Determine PTO RPM's ? #5
Remember, the only stupid question is the question not asked. Or as my old man used to say, "There are no stupid questions, but there are a **** of alot of stupid answers." /forums/images/graemlins/tongue.gif
   / How to Determine PTO RPM's ? #6
Well here is a good answer -> our Kubota L-3130 has a live PTO rpm tachometer specifically monitoring the PTO rpms from 0-540 rpms in real-time, not some spot on the engine RPM tachometer where the PTO should be running at 540rpms.
   / How to Determine PTO RPM's ? #7
There may just be a line.. or it could say 540 or 538.. or could have a graphic of a small gear spinning.
Soundguy
When I got home last night, I went over to the orange beast and looked at the dash.
YUP ! Sure enough, there "IS" a line at about 2500 RPM that says "PTO 540". I've had the tractor for almost 7 years and never really paid attention.
Thanks again....
Tim
Now... as a follow up question.
Can I run the engine at a "Higher" RPM and exceed the PTO RPM's of 540 without damaging my snowthrower?
I was running it at about 2800-3000 since it would throw the snow farther at the higher speed.
I really don't "think" it would hurt it, but would like some input from more educated operators.
Thanks, Tim
   / How to Determine PTO RPM's ? #10
<font color="blue">
</font>
TimP, you've had the tractor for 7 years, and you've been running the snowblower at 2800rpm, which is something over the 540 PTO rpm all this time. I think you answered your own question.
But consider the gearing. It takes 2500 engine RPM to get the PTO to run at 540, so there is ROUGHLY a 5 to 1 gear down. Running at 3000 engine RPM is going to put the PTO RPM at roughly 600? I suspect there is enough safetly factor engineered into the gear box of the snowblower to handle that.
BARBED WIRE (A58214)
Spirit scooter (A55787)
Spirit scooter...
2014 Mazda CX-9 Sport SUV (A56859)
2014 Mazda CX-9...
Mini Excavator (A55787)
Mini Excavator...
2025 epic golf cart (A55758)
2025 epic golf...
LOT: (48) 14 Oz. Tubes of Premalube Heavy Duty Multi-Purpose NLGI #1 Grease (A59076)
LOT: (48) 14 Oz...
