How to follow water pipe?
   / How to follow water pipe? #111
.............Since my wife apparently posses unusual powers I will try to talk her into dowsing and report how it worked for her.
When I tried it, I was surprised at how robustly the L rods moved. I gave them to my wife and asked her to walk the same route and it repeated for her, as well. Weird. :confused2:
   / How to follow water pipe? #112
As luck would have it, I have to locate my well water line to extend a branch pipe to our new barn later this summer. I'll bend up a couple of rods and see how my "divining skills" are these days. I DO know they worked for me a couple of years ago when we witched our well location for a new house.
I should qualify the "worked" part of that. Three of us tried it, the well digger first, then skeptical me, then the astounded wife. We all got the same results, and the well has lots of water. Mind you, we could possibly have dug anywhere and got a good well, that I don't know.
I do know roughly where the water line is going into the house, I'm just trying to avoid unnecessary digging by witching it exactly. The well digger told me he could usually locate sewer and water lines as long as there was some water flowing through them, so I'll turn on a tap to get water flowing into the house (pump running).
Video to follow sometime in the next few days, whether it works or not.
Sean
   / How to follow water pipe? #113
It's been quite a while since I've posted, and I don't really feel up to getting into a hornets nest, but thought I'd throw in my .02...
Around these parts, it's difficult to find any type of underground line - even the utilities have trouble with lines. Case in point - while working on a water leak at my grandparents place a few years ago, we dug up a black iron gas main the gas company had no idea even existed. It was only a few feet deep, was leaking(anybody who has clay soil with a high water table knows how long that stuff lasts...) and was 30' (according to the gas company survey) from where it was supposed to have been. When they checked the spot where it was supposed to have been, there was a gas main there as well, so it was orphaned and forgotten about long ago, before my grandparents bought that place in the 70's.
When my uncle died, my parents bought a place just a short jump from my grandparents so they could take care of them. Yet, it was far enough away that my grandfather had no idea about any of the lines and such underground. When we went in to install a back yard drainage system, we called the utilities to mark their lines (knowing what little good that would do) and called my grandpa to get his take on things. He showed up with a few feet of #10 copper wire and a grin on his face.
He cut it in two equal lengths, bent handles on one end of each piece and took off. We have a barn at the end of the property (adjoining the road) and always assumed there was a wire coming from the house (the garage electric was ran from the house, so why risk it running from the garage) and sure enough, he found a line running from the house to the garage and the house to the barn. What he found next was unbelievable - a wire running from the garage to the barn as well.
I thought he was crazy, and so did his brother - the backhoe operator. Until, right under one of his flags, his brother hit one of the wire and cut it in two (without kicking a breaker) at the depth he said it would be. He was apparently able to tell if it still had electricity going though it as well (warning his brother it was hot before he cut into it with a pair of linemans pliers, ruining them and coming close to setting himself on fire with the arc). That day, I learned two lessons - Don't discount the old ways (People survived before the advent of digital electronics. Go figure, right?) and great uncles are flammable, or at least, their clothing tends to be.
Now, I'll admit, I have a college degree in electronic engineering and I have no idea how, why or if it works. But, if it works for you, go for it. If you've never tried it, grab a few copper rods, a case of beer and a shovel and give it a try - you are only out a few hours and some manual labor if it doesn't (or just a few hours if you have a backhoe). Who, realistically, has the ability, time or money to rent a Ground Penetrating Radar unit and operator for simple things such as finding a PVC water line. Around these parts, you either do the copper rod trick, do some old fashioned detective work or start digging "where you think it is". Usually you do a bit of all three, with fairly good results.
Perhaps it's all about perception - your subconscious telling you where something should be and it manifests in your hands. Perhaps it really works. I don't know and I don't think we'll know in my lifetime. But, it's not worth the cost of an aneurism debating it.
   / How to follow water pipe? #114
I rate this the best post so far!
James K0UA
   / How to follow water pipe? #115
Redneck in training said:
Did it ever happened to you that you look into a fridge to find in example mustard and it is not there. Then your wife opens the fridge and the mustard appears, like a magic, in her hand? Happens to me all the time.
May I humbly suggest that you have a supernatural inability to see things that are right in front of your face?
   / How to follow water pipe? #116
Here's what I do to locate lines and the like...
Take two 24" pieces of bare 12 gauge copper wire bent about 6 inches from the end in a right angle. Loosely hold one piece in each hand. with your elbows at your side, and hands out front, walk slowly across the area. When you cross the pipe, the wires will cross. Working in a ziq-zag, you will be able to locate the line in question.
I know there will be doubters to this process...but I'm tell'n ya, it can and will work. Verify your own success by walking where the pipe is in a known location. You will have to experiment and adjust your grip, remember the wires must be held loosely.
I've found PVC 4' deep covered in rock and soil. Electrical lines 24" deep, and plastic water lines 5' deep. It's not going to cost you but a few cents in material, but give it a shot.
I use gas welding rods and it works everytime!
   / How to follow water pipe? #117
I've not tried those...just the brazing rods and copper wire...my wires get pretty mangled. I'm guessing anything more rigid than the copper wires woud be better!
   / How to follow water pipe? #118
Me too, Me too I have that....at least my wife says so!
   / How to follow water pipe? #119
I've gotta dig out me coat-hangers and get a haircut if I'm gonna be famous. Me mother always said to make a good first impression..:laughing:
Sean
   / How to follow water pipe? #120
Lol, it must be a common ailment, been guilty of that myself quite often.
Ever since I said "I do" I've had trouble hearing as well. Wonder if the conditions are related? If so, I only see one common factor :D
2016 STOUGHTON 53FT DRY VAN (A57880)
2016 STOUGHTON...
2017 Chevrolet Tahoe SUV (A55853)
2017 Chevrolet...
2018 John Deere 470G Hydraulic Excavator (A56857)
2018 John Deere...
2011 GMC Yukon XL Denali (A56859)
2011 GMC Yukon XL...
2007 Reitnouer 40 Ton T/A Heavy Haul Flatbed Trailer (A55973)
2007 Reitnouer 40...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
