How to get gravel out of pipe?
   / How to get gravel out of pipe? #1
Pilot
Oregon
JD 770, Yanmar 180D, JD 420 (not running), had a Kubota B6200
Aren't 3 year olds wonderful?
Vertical pipe, maybe 3/4 inch I.D. sticking 5" out of the ground. 3 yr. old grandson filled it with gravel in the 30 seconds when I wasn't watching. I should have know--he likes to stick rocks into things.
The pipe is kind of important. It's at the airport and holds the hangar door open. A section of rebar is supposed to drop down into the pipe from the hangar door and should sink down at least 10". Doesn't work any more...Can't fly any more until I fix this so the door will stay open to move the plane in and out.
So how to get crushed 3/4 minus gravel out of this pipe?
   / How to get gravel out of pipe? #2
If the pipe in the ground is thick enough walled, you could probably use a hammer drill to clean it out.
Otherwise, I would cut or break it off, at the slab or ground, drill it out, and replace it.
I am sure you know, lots of bad things can happen to children at airports. Even in 30 seconds.
   / How to get gravel out of pipe? #3
Drill a hole low in the pipe and try to blast it out with compressed air?
Wear eye protection if this idea seems worth trying.
   / How to get gravel out of pipe? #5
I was thinking shop vac also, or a set of tongs.
   / How to get gravel out of pipe? #6
I would try a shopvac. If that doesn't work on its own, adapt it down to a 12" piece of 1/2" OD pipe and use that to suck the pieces out.
Aaron Z
   / How to get gravel out of pipe? #7
I have cleaned out those pipes with a long flat screwdriver, slow work, but it works.
   / How to get gravel out of pipe? #8
Aaron Z
:thumbsup:
Thats what I would try.
Even if it doesnt "suck-up" the gravel into the shop-vac, a decient one should have enough vacuum to "ctick" the rocks to the end like a magnet. Pull it out, knock them off, and go again.
   / How to get gravel out of pipe? #9
Aaron Z
Aaron...your suggestion will work ...I have done it..the key is to adapt the shop vac hose down to a 12 inch piece of 1/2" od pvc and it concentrates the sucking action..it will lift the gravel right out if it is a good shop vac.
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
2010 Massey Ferguson 2625 (A60462)
2010 Massey...
2023 JOHN DEERE XUV 590M S4 UTV (A59823)
2023 JOHN DEERE...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
Kubota SVL 75-2 (A53317)
Kubota SVL 75-2...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
