GPintheMitten
Elite Member
- Joined
- Sep 8, 2009
- Messages
- 3,331
- Location
- Flushing, Michigan
- Tractor
- Kubota B2620 with BH65 backhoe, Ford 2N
I like the ingenuity shown by forum members.
You really only need 250 lb of force to lift one end of a 500 lb safe.
One floor joist, especially near a supported end, is easily capable of taking that force without any problem. I am not sure about screwing a lag bolt into the bottom of the joist and having the lag bolt hold, but if the ceiling is not finished and the joists are accessible drilling a 1/2" hole through the joist near the top side would allow a machine bolt with a loop of chain as an attachment point.
Taking the door off first is a good plan. That will reduce weight considerably.
I lift my JD 135se lawn tractor from a floor joist with a eye-bolt screwed into the joist.. I would not hesitate to put 500 lbs on it. Call me crazy...
Also, I doubt you're putting yourself in the path of 500#s of weight from your lawn tractor over your head, but I could be mistaken if you lie on the floor under the mower while it's suspended by the screweye?
CM, now that you have it moved [Good job] what are you going to put in it? Chainsaws?
OK, you're crazy! A screw eye, or eye bolt is not made from metal designed for overhead lifting, and is not rated for this type of work, especially 500# or more.
Nope, I might be crazy, but I ain't stupid.. Oh, and I don't carry while working on the mower either..![]()
Golf balls, Now that's a smart idea!!! How did you think of that?
