How to paint raised lettering on tractor
   / How to paint raised lettering on tractor #1
krogers
ford jubilee
Have any of you learned a good way to paint the raised lettering on tractor body work? I have been trying to find a way to do this on my Ford Jubilee. I tried using a sponge with paint on it by lightly pressing onto the letters but that did not work. I see decals advertised. I will research if that would be an alterative. Thanks.
   / How to paint raised lettering on tractor #3
You might try this.
Apply grease to the lettering - then using a firm sponge with an absorbent cloth, wipe the grease off the letter surface you are wanting to paint (spray). Wipe with a solvent also to remove grease before painting. Spray the letters and let dry - then remove the rest of the grease. I used to do this for parts of a car when I spray painted the car.
The decals sound good also.
   / How to paint raised lettering on tractor #4
Or tape over the entire area & cut out the letters from the tape shield with a razor knife.
   / How to paint raised lettering on tractor #5
All my life I've been curious how Ford did it at the factory?
   / How to paint raised lettering on tractor #6
I think they also sell a spray "blocking" that dries to the consistency of contact cement or light rubber. Spray off the area & cut out the letters to make a temporary stencil. then remove the rest when done.
or
   / How to paint raised lettering on tractor #7
Painted letters with a brush. I had old tractors with brush marks. You could tell as it was fading away. Just paint hood or whatever, paint raised area with a brush. Easy.
   / How to paint raised lettering on tractor #8
I used a foam roller, still needed a rag with thinner to clean some areas.
David
   / How to paint raised lettering on tractor #9
Interesting replies. (y)
   / How to paint raised lettering on tractor #10
2022 Suzuki King Quad 750 AXi 4x4 ATV (A46684)
2022 Suzuki King...
2015 Mini Cooper Hatchback (A48082)
2015 Mini Cooper...
45017 (A48082)
45017 (A48082)
Mahindra 4110 4WD Tractor (A49251)
Mahindra 4110 4WD...
Fimco 3pt Sprayer (A49251)
Fimco 3pt Sprayer...
2021 23ft Cypress Cay Seabreeze 232 Pontoon Boat with 23ft Single Axle Trailer (A48082)
2021 23ft Cypress...
